20 Most Recent
Xact Communication M3XBK (14 Channels) 2-Way Radio Questions & Answers
We need a battery XB 12
Do a search on eBAY. There are lots of second source batteries there and they seem to be decent quality. I have bought many for all sorts of devices from these venders.
2/3/2015 7:19:21 PM •
Xact...
Answered
on Feb 03, 2015
Hello, where can I get wall charger for Xact x2x
your device should be marked with polarity and voltage requirements. Any power supply with the correct plug meeting those specs (if amperage isn't marked, look for one that is between 500- 1000 mA) should be fine. MAKE SURE it is a DC supply if the device you are using is marked DC.
10/23/2013 3:32:50 AM •
Xact...
Answered
on Oct 23, 2013
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
8 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
