20 Most Recent RTO Letro Jet Vac Automatic Pool Cleaner without Booster Pump Questions & Answers
The jet vac pool cleaner is around 9 years old. I
There has been 9 years in cleaning advancements. Up grade and enjoy
3/5/2019 1:31:20 AM • RTO Letro Jet... • Answered on Mar 05, 2019
No reverse
The gear placement is irrelevant. Is the propeller binding up? Also check for debris in the reverse jets. The beauty of the Jet Vac is it's simplicity,
11/12/2018 4:58:35 PM • RTO Letro Jet... • Answered on Nov 12, 2018
WHEN JET VAC HAS FINISHED CLEANING AND STOP THE LEAVES ETC FALL OUT OFF THE BOTTOM
The bag is supported by the jet of water shooting into it. When the pump stops, the jet stops and the bag should fall over sideways, retaining the leaves. I'm curious, Letro was bought out by Pentair 10+ years ago and the Jet Vac was discontinued. Also the description says that this cleaner runs without a booster pump. Every Jet Vac I have ever met runs with a booster pump. Are you sure the installation is correct?
12/2/2017 6:10:19 AM • RTO Letro Jet... • Answered on Dec 02, 2017
2answers
Wall fitting filter screen clogs
Craig - your filter elements in your pool filter are probably ripped (one or more) allowing whatever it is filtering to come through. This could be leave particles, DE, pebbles - whatever is sucked through your filter. The filter (at the wall) is performing it's job, and stopping this from then entering your Jet Vac, and clogging it up also, worst case ruining the gears inside the Jet Vac.
3/15/2015 2:04:50 PM • RTO Letro Jet... • Answered on Mar 15, 2015
0answers
0answers
0answers
0answers
LETRO POOL CLEANER WITH BOOSTER PUMP NOT SUCKING MUCH.
Is it a jetvac? you said the bag does not stand up, I'm sure it is a pressure cleaner, the pump maybe no good or your pool pump is not providing anough water for the pressure pump. Check every thing, hair and lint pot on pool pump should be full, clean filter. [email protected]
5/24/2010 1:16:15 AM • RTO Letro Jet... • Answered on May 24, 2010
My letro jet will not move, I have booster pump
Check the thrust jet and head jets for debrie
8/23/2009 5:13:22 PM • RTO Letro Jet... • Answered on Aug 23, 2009
Trying to find a repairman to look at my dolphin
contact us through www.arrowpools.net and select the dolphin service button along the bottom.
6/27/2009 7:07:53 PM • RTO Letro Jet... • Answered on Jun 27, 2009
Onga pumps questions
Please give more detail.
1/18/2014 2:57:34 AM • RTO Pool & Spa • Answered on Jan 18, 2014
2answers
LifeSmart LS350 Plus Hot Tub Jet Spa. Can I convert my LifeSmart LS350 Plus 110v to a 230V
Question edited for clarity. Question moved from Computers category. Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power. https://www.google.com/search?q=lifesmart+ls350+plus+220+volt ..
4/14/2024 9:55:26 AM • Pool & Spa • Answered on Apr 14, 2024
2answers
How do you clear a general fault on the power supply of Minimax NT5000 24V/15A-HR?
Contact the manufacturer 1 800 863 3930 for specific information about this. The manual does not include information for getting rid of a general fault. https://www.alpha.com/download/outside_plant_power/cableups_power_supplies/broadband_ferro/install_oper_manual.pdf
3/17/2024 4:14:55 AM • Pool & Spa • Answered on Mar 17, 2024
RTO Letro Jet Vac Automatic Pool Cleaner without Booster Pump Logo
Popular Tags
20 questions posted
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Kardoc
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
RTO Pool & Spa
  • RTO Pool & Spa
Most Popular Question
wall fitting filter screen clogs
  • Pool & Spa
