20 Most Recent
Hayward Aquabug Above Ground Pool Cleaner Hay500 Questions & Answers
Wont move in pool or
There are several things that could cause slow or non movement. I would first check your water pressure to be sure that it is correct. Make sure that your filter and any leaf or debris baskets are clear. If something is clogged, it will decrease your water flow and cause a lack of movement in the
pool cleaner. Also, make sure there is not a blockage in the cleaner's throat. Finally, make sure that your cleaner's shoes and wings are not worn. If they are showing any signs of wear and tear, they are probably not allowing the cleaner to seal to the pool floor. Replace them and see if that corrects the problem.
Why do diver dave's feet keep stopping
Internal gears may have foreign matter in there and then the gears get stuck. Need to disassemble and clean out debris. Could be leaves, twigs, hair, etc.
