20 Most Recent
Dolphin Maytronics Advantage Questions & Answers
My dolphin begins to work, then stops. What could
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. Make sure there is no water in the handle and that the brushes arent worn. If the cleaner is too light, add weights. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure there is nothing caught in the impeller.
10/20/2020 4:00:58 PM •
Dolphin...
Answered
on Oct 20, 2020
My Dolphin turns on and
I’ve been having this issue on and off for about two years now. There’s a pretty easy fix, or at least patch, since this issue will come back from time to time. Unplug everything, the power-cord from the wall outlet and the aquabot from the power supply. Turn the aquabot upside down and leave it alone for 5-10 min do any stored power completely drains. After 5-10 min plug everything back in and turn on the power supply with the robot still upside down. It will go through a test phase where it will spin both directions and various speeds. This will last about 30-40 sec. Once the test is over, turn it off, put it in the pool and turn the power back on. It should work properly. If the test phase only lasts a few seconds or more that 2 min. Unplug everything, wait a little longer, and start over again.
10/20/2020 3:56:06 PM •
Dolphin...
Answered
on Oct 20, 2020
Pool cleaner works 5 minutes and stops
Thank you for posting your question here on Fixya.com.
It can be a couple of possible issues which will require service at a service center. For warranty consideration, please fill out the contact information and a description of your problem on the dolphin service page at http://www.arrowpools.net/ (select Dolphin Service along the bottom) and we will respond with shipping instructions to begin the repair process.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
9/5/2014 11:31:43 PM •
Dolphin...
Answered
on Sep 05, 2014
The two wires that go
use a 1.5mm allen wrench to loosen the set screw in the side of the plug and then insert the allen wrench into the hole and bend the shim back to make room for the wires. The white goes into the 2 hole and the black into the 3 hole.
John
5/23/2014 4:12:09 PM •
Dolphin...
Answered
on May 23, 2014
