20 Most Recent
AO Smith Centurion 1081 1.5 Hp Standard Threaded Shaft Motor Questions & Answers
Need wiring diagram gould 8-152690-2
If it is the small cover and not the complete cap style at back of motor, ?..
pit is at times, behind metal cover where the wiring is.
Sometimes it is behind the foam insulator.
5/10/2015 5:46:23 AM •
AO Smith...
Answered
on May 10, 2015
I have a Gould 1081 pool pump and the motor runs and the pum po works great but after 3 or 4 minutes there's a click and the motor cuts off. After a few minutes theres another click and I can restart
The motor should separate from the pump, there's a big o-ring. Sounds like the motor is overheating. When out, check the impeller for debris, and it should spin freely. If it doesn't spin freely, you need a new motor, changing bearings is not easy.
Don't throw away the old motor, it has other parts that may come in handy some day.
Also, when you get a new motor, a new impeller will be a good idea. Getting the old impeller off is a trick, maybe the dealer will do it for you if the old impeller looks ok.
11/30/2013 3:24:00 AM •
AO Smith...
Answered
on Nov 30, 2013
Ours is loud its a 2.0 hp
As pumps age, the bearings wear out. You may be able to get the bearings replaced at a rewinding shop. They can check your windings at the same time. It's always a good idea to have a spare pump handy. That way there is no down time while one is being fixed. A pool can get out of control quickly with no circulation.
11/29/2013 11:04:46 PM •
AO Smith...
Answered
on Nov 29, 2013
