20 Most Recent
AO Smith 1.5 hp 3450rpm 56J Frame 115/230 Volts Hayward Northstar Swimming Pool Pump Motor - Electric Motor Questions & Answers
Engine knocking noises
Impeller could be plugged?
Diffuser may have become misaligned and hitting the impeller?
May have sucked up some foreign debris?
Knocking could be a bad bearing.
Just replaced motor overheating and shutting off.
service factor must match old motor ! motor must match impeller hp rating ! .. get the numbers off the impeller and search it on the web.. bet your motor is too small.. the easy fix ? buy the right impeller for your motor.. the things you need when buying a impeller are as fallows.. your motors hp and SF .. thats the service factor !
if the voltage is 120 v the motor set on 240 it will jump back and forth between start and run.. it will make a click ..click ..click noise .USE A VOLT METER. I smell a northstar a real pain of a pump..
REMEMBER TO BUY AMERICAN PRODUCTS (PLEASE) AND SUPPORT YOUR LOCAL POOL PUMP REPAIR GUY.. AND GIVE ME A THUMB OR TWO ,IF;N YA FEEL I WAS OF HELP ..JAY FLORIDA
