20 Most Recent
Hurricane Pride PMV Mobility Scooter - Viper Blue Questions & Answers
No power to anything
hi its no use checking youre batteries with a voltmeter .multimeter this will not tell u how the condition of the batteries r u need a battery load tester to check condition of the cells ..u can buy them of E/BAY.....good luck
Horn will not sound pride hurricane
The horn is a a small peizeo horn. You can generally get them at radio shack. The horn voltage is 24v. Before you run and get a horn, you need to see if the horn accidentally was disconnected due to a bad solder joint or the wire had been accidentally pinched and cut from a previous service. This horn generally does not go bad. The button on the dash is usually the culprit. While you have it apart you need to look at the button closely. The best way to check this this to have the scooter on and touch both wires in the bottom of the switch with a screwdriver and see if the horn sounds. If it does, replace the switch. If it doesn't, then it is either the horn or a bad circuit. Depending on how comfortable you are messing with electricity. You can apply direct voltage from the batteries with a jumper wire and see if the horn works or you can use a voltmeter to check the circuit. I usually just use the jumper wires. It's fast and easy. If horn works then it's in the circuit, if it doesn't you have to start with replacing the horn.
My scooter has power but won't move and it flash
Error code 8 means an internal controller error or problem and requires replacement of the controller. If Medicare purchased your scooter then contact a provider to get repaired or you can call a service company such as Roadrunner Mobility at 1-800-467-2668 or Repair Xpress at 1-877-581-3733 and they will bill Medicare for most of the repair costs. Hope this helps
Where is the serial no
It's on the inside of the tiller which you have to unscrew from the bottom of the handle bar
Has more power going in reverse then forward
Sounds like the motor polarity has been reversed. Have the motor wires been disconnected recently. If so they MAY have been refitted the wrong way round but this would be difficult as the plug that connects them should only fit together in one way so shouldnt be able to fit together the wrong way. Could also be main control box. I have seen this happen in the past! You need to see a dealer with a diagnostics machine. They should be able to correct the problem. Hope this helps...
Which is good food for health?
A balanced diet of meat, fish, vegetables, fruit and nuts, with a moderate amount of beer and red wine plus lots of water.
How effectively to loose weight?
Losing weight effectively involves a combination of healthy eating and regular exercise. Consider exploring Dr. Nowzaradan's diet for guidance on sustainable weight loss practices. Additionally, prioritize adequate sleep, manage stress levels, and stay hydrated. Remember, consistency and patience are key on your weight loss journey. Learn more here:
https://betterme.world/articles/what-is-dr-nowzaradan-diet/. Good luck!
How to lose weight in 2 weeks - tips to follow
To lose weight,
* it is crucial to cut down the consumption of store-bought meals or ultra processed foods
* to start eating whole foods
* start including healthy fats and increase protein in your diet
Example meals:
Breakfast: Scrambled eggs and cheese (3 or 4 eggs)/cheese egg sandwich/egg toast/cheese egg omelette with some veggies and fruits (include avocado)
Lunch: Red meat/chicken with some rice and veggies
Dinner: Same as lunch
Can include coffee in the morning with less sugar. Try to avoid buying food from outside for 30 days and try this challenge to see drastic results. It is also recommended to bake your own bread. Cook your food using butter and NOT USING other oils. When you crave for sugar, try to snack on few dates stuffed with butter.
