20 Most Recent
Pride Mobility Products Casual CL20KD Lift Chair Chestnut Questions & Answers
Electronic Control Box Module on Triton PL3-01 not working
I have a pl3-01 scooter in for repairs and 3 resistors on the circuit are fried and I can't get the color coding of the resistors to replace them. Can you send me a picture of your circuit board and I will see if I can fix this 1, and if I can, maybe I can help you out.
I HAVE PRIDE VICTROY 10-4 WHEEL MOBLILITY SCOOTER
Hi , in the manual l it's known as a (8) Motor volts error. I strongly suggest you check all connections , check the brushes making sure they move freely and the strings okay spray in some contact cleaner and refit, once again check all connections, what the error actually means is that the rsistance for the motor is wrong , so the above check should address the issue..Regardswww.gewizrepairs.co.uk
Switch Wireing Diagram
The motor operates on low voltage DC current Robert. You will have a negative and a positive, like a car. The center connector is a common, meaning that it will be connecting to the motor whenever you switch is activated to make it go, and the other two are positive and negative to control either up or down. These should be color coded red and black and will go to the outside connectors and the remaining wire will go to the center common connection. Hook it up and then test the chair lift button. If it doesn't lift, you need to reverse the two outside wires for correct polarity, or just use the switch controls opposite; up for down, down for up.
My pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
