20 Most Recent One For All URC-9910 LCD Remote Control Questions & Answers
One for all universal
hola me podria decir codigo de kirsch loud receiver ampliflier 5.1
4/15/2019 2:05:06 PM • One For All... • Answered on Apr 15, 2019
I have a LG TV & need code for one for all remote URC3021B00
LG started out as Goldstar, merged with Lucky Corp., to become Lucky Goldstar, LG ;-)
Although your remote doesn't list any codes for LG, one of the Goldstar codes may work.
Try 0030, 0056, 0178.
If that doesn't work you may have to try the "Search for Code" feature by first turning your TV on, then follow these steps:
1.On the remote control, press TV once
2.Press and hold SET until the LED (red light) blinks twice,
then release SET.
3.Enter 9 - 9 - 1.The LED will blink twice.
4.Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5.To lock in the code, press and release SET.The LED will
blink twice.
The URC-3021 is a 2004 basic model without any learning capability, if you are unable to find a code, it may be time to buy a new remote.
There are newer, low cost universal remotes available at Walmart, Target, K-mart, and other retailers, that should have a more up-to-date code list.
Hope this helps, Greg
7/21/2014 2:48:18 AM • One For All... • Answered on Jul 21, 2014
What codes do I use on the urc 9910 for att u-verse?
I don't think att u-verse existed when the 9910 were made so there probably isn't a code in the remote. And as far as I can tell the upgrade program for codes for new products is dead, dead, dead. The only option I know is to use the JP1 connector under the battery door to program a new code. I just added several links to information on this to the tips & how to's section for this. If you are good with computers check them out. Scrool to the bottom of the link to find them. Good luck! Troubleshooting Support for One For All URC 9910 LCD Remote Control
7/8/2014 8:40:04 AM • One For All... • Answered on Jul 08, 2014
NEED TO ADD CODE TO URC REMOTE
Try these instructions and see if they work for your genie remote. First, have your Genie Mini receiver connected and powered on. Next, grab your RC71 remote and simultaneously hold the "MUTE" + "ENTER" buttons until you see a box appear on your TV screen that says "Applying IR/RF Setup. Please Wait" (this appears after about 5 seconds of holding those buttons). Once complete another dialog box will appear and read, "Your remote is now setup for RF." Click "SELECT" to exit that screen. Next, click the "MENU" button, scroll down to "Settings & Help", then click on "Settings", scroll down to and click on "Remote Control", then click "Program Remote". Next you will have two options, either "Program TV" or "Program Audio Device". Click "Program TV", this takes you to a screen where you need to select what BRAND your TV is. After you have selected your TV brand you will have to select the TV Model ( I recommend looking at the sticker on the back of your TV for the accurate Model number or using your current TV remote to find the model number from the menu screen on your TV for fastest and best results). Once the correct model number is selected, AIM your RC71 remote at the TV and it will AUTOMATICALLY program!
6/20/2014 2:17:48 PM • One For All... • Answered on Jun 20, 2014
I have a lg tv 21 inch but i forget my remote number plz help
0056 is the only code listed in the manual for LG TV. http://www.manualslib.com/manual/302162/One-For-All-Urc-9910.html If this doesn't work you will need a connector cable between a computer and the remote and some computer skills to use the JP1 connector under the battery compartment door to find and add a new code to the remote. JP1.x connectors will need an adapter to fit. http://www.hifi-remote.com/jp1/help2/ http://www.hifi-remote.com/jp1/ will get you started. Any search for JP1 REMOTE PROGRAMMING should get many results too. I have about a dozen of these remotes but they are so old many of the codes are out of date. I have not been able to make any of the JP1 cables I have work on my computer. I was lost when it told me I needed to configure a port. While these are/were fantastic remotes regardless of their low price, you have to remember they have been out of production for many years. One For All stopped the phone upgrade code program were they would find the code for new equipment and program it into your remote over the phone. They will not honor it's Guarantee to replace it with a remote that will work you IR equipment. I contacted them with my receipts and was rudely refused, then ignored. Good luck! Ron
6/20/2014 2:02:16 PM • One For All... • Answered on Jun 20, 2014
Need codes for my LG TV
First try all the codes listed under LG TV in the manual. If none of those work ther probably isn't a code that will work in the remote. I have had no luck in calling the number in the manual to get new codes downloaded into the remote via phone. I also sent an email asking for a replacement that would operate my DirecTV Genie DVR. This was their Guaranty when they sold the 9910. They simply told me they would not honor it. And I told them very clearly what I thought of them, not that it helped solve the problem. But there may be a solution! Under the battery compartment on the remote is a connector. On this model it is a JP1 (Not a JP1.1, JP1.x). You will have to find a cable with JP1 on one end and something that will connect to a port on your PC. Then you may be able to download a free program and add the LG TV code to your remote. And also do a lot of other amazing things. Warning, I have not been able to do this. I do not know how to 'configure a port', but if you have these and other computer skills maybe it will work for you. Here is a link to get you started: http://www.hifi-remote.com/jp1/ Good Luck!
6/6/2014 5:17:25 PM • One For All... • Answered on Jun 06, 2014
Need a code for a onkyo 5.1 av receiver tx-nr509
0029,0021,0027 are the general codes to check with this brand audio device. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts. http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
12/19/2013 2:40:43 PM • One For All... • Answered on Dec 19, 2013
Code cisco cable box cox
0028,0025. Try these codes. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy.
11/3/2013 7:35:05 AM • One For All... • Answered on Nov 03, 2013
Samsung HT-BD3252, the DVD player stays on ' Load
Program your universal or LCD remote to operate DVD player codes 182 & 230.
8/17/2013 3:32:50 PM • One For All... • Answered on Aug 17, 2013
Tv remote controls codes
What is the brand name to your TV? Provide more details please. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. More than Nine Lacks viewers cannot be wrong.http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
5/6/2013 11:42:46 AM • One For All... • Answered on May 06, 2013
Reprogram the URC-9910 universal remote for VIZIO E3D420VX
Universal remote code to check with Vizio TV is [0081.Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. If you want to get more details and codes to different remote controls, check this.
12/30/2012 4:12:31 PM • One For All... • Answered on Dec 30, 2012
LG remote MKJ36998126
What is the problem with your LG remote?
4/22/2012 3:26:16 AM • One For All... • Answered on Apr 22, 2012
0answers
Need a code for URC-9910B01
Call All-For-One and get remote upgraded. 330-405-8616.
8/30/2011 4:52:44 PM • One For All... • Answered on Aug 30, 2011
12answers
Jumbo Universal TV Remote (Sharper Image-Innovage)
sharper image jumbo remote can't get it to program my philips/magnavox tv.
10/28/2010 2:52:18 PM • One For All... • Answered on Oct 28, 2010
Cant get remote to connect with tv 3 digit codes
hello.........myhavehivionreseverplese...........mastar.........code......hivon9090x
8/8/2010 12:14:26 PM • One For All... • Answered on Aug 08, 2010
2answers
I can't find my manual for my sharper image jumbo
Send me your email address and I will send it to you.
[email protected]
AL
4/30/2010 4:45:19 PM • One For All... • Answered on Apr 30, 2010
Sharper image jumbo remote to work with dish network
I can help you with your Sharper Image Jumbo remote control.
There are two Sharper Image Jumbo Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals. The included code lists will give you the correct codes you require.
The Jumbo Touch also has a learn function, while the standard jumbo does not.
I hope that helps.
4/30/2010 4:41:59 PM • One For All... • Answered on Apr 30, 2010
One For All URC-9910 LCD Remote Control Logo
65 questions posted
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • One For All Televison & Video
Most Popular Question
lg tv amp need code one all remote
  • Televison & Video
