20 Most Recent Salter Stainless Steel Electronic Bathroom Scale Questions & Answers
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
11/4/2015 11:01:00 PM • Salter Stainless... • Answered on Nov 04, 2015
Model 9114 salter scale shows Lo. I have changed the batteries but it still only shows Lo.
I had the same problem and, suspecting that the metal contacts weren't making proper contact with the batteries, I used a long nosed pliers to gently bend all ten contacts towards to the batteries (there are eight small tabs in the battery compartment, and two on the battery cover). If you don't have a long nosed pliers a small screwdriver should do it if you held the fixed part of each set of contacts so it doesn't detach during the process. Unfortunately, it worked, but only for one weigh, and then it reverted to "Lo". This happened twice, so I telephoned the Salter Customer Service Helpline (01732 360783) who recommended a reset, which is done by removing the batteries, standing on the scale for 20 seconds, and replacing the batteries. That also only worked for one weigh, so they are looking into it further and I'll post the results here, but in the meantime I hope one of the above solutions will work for others.
11/23/2014 12:31:31 AM • Salter Stainless... • Answered on Nov 23, 2014
0answers
Salter Stainless Steel Electronic Bathroom Scale Logo
167 questions posted
Top Salter Health & Beauty Experts
vince
jws1013
Ngoro
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Salter Health & Beauty
Most Popular Question
own salter stainless steel electronic
  • Health & Beauty
