20 Most Recent Electric Power Team Hydraulic Pump - Single Acting PE172 Questions & Answers
Check the following:
AVR
doids windings
stator windings
rotor windings
exciting windings
AND
Exiting windings could have losts its 12volt exiting load. In that case it must be exited by 12 volt external battery
Another common problem is burned off wire or loose connection
Electric Power... | Answered on Sep 12, 2018
The pressure relief valve will be to low, or your load will be to heavy.
Kind regards Marcel van ****
Electric Power... | Answered on Feb 10, 2010
Connecting 12 batteries in series would give slightly more than 61 volts. Considering that under load voltage will drop then it should be ok. Breaker goes between battery and motor on positive wire.
Electric... | Answered on Oct 14, 2019
Hi!
We help people repair their Clarke Generators. You can find testing procedures here: https://www.generatorguru.com/contact-us/
We also hold all the parts possible for all the Clarke Generators and have a "Parts Search Service" if the part is not listed on our site. Check us out on our site.
Parts Spares for Generators and Small Engine Machinery
Electric... | Answered on Sep 13, 2019
either short or failure of gfci
Electric... | Answered on Jun 08, 2019
Tip
Repair broken power cord
I have a 50-ft power cord for my electric pole saw. In an accident, the saw cut the power cord. It's long cable and I want to save it. My method keeps the cable lean and retain it's strength. It's not water-proof, but I never use a pole saw in a rainy day.
on May 31, 2019 | Electrical Supplies
If you make your point of reference the flywheel (starter side) of the motor then rotation is clockwise. If your point of reference is the alternator or the end opposite the motor flywheel, then it will be CCW.
Electric... | Answered on Apr 26, 2019
If you use a car battery you cannot go wrong. Jumper a car battery!
Electric... | Answered on Apr 10, 2019
Go to google put in the item you're looking for and it will be there for you
Electric... | Answered on Feb 21, 2019
There are many ways to start. First, the starter is weak, and the second is that the starter does not move. If the latter, check the controller for signal output. If there is no signal output, check the battery for voltage? If there is pressure, the controller may be broken.
Electric... | Answered on Dec 19, 2018
depends on how many amps you are drawing at any given time??? whats your max draw??
Electric... | Answered on Nov 12, 2018
Electric Power Team  Hydraulic Pump - Single Acting PE172 Logo
Popular Tags
2 questions posted
Top Electrical Supplies Experts
Fahr Quad
NOEL
NOEL
vince
Are you an Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
Electric Electrical Supplies
  • Electric Electrical Supplies
Most Popular Question
electric generator not producing
  • Electrical Supplies
