20 Most Recent
Black & Decker SV1000-4 SteamBuster Vacuum Questions & Answers
No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
You can download the manual from the link below:
http://www.dewaltservicenet.com/ServiceNet/Logon.asp
You will need to register but it's free.
As you know there's not much to the spray function but you should hear a pump running when you push the switch.
You may need to clean the dirt bowl & filter for better results this is described in the manual.
Please update the question & let us know if the information given was useful to you - Good Luck!
