20 Most Recent Electric Fuji Cp32fm Circuit Breaker Questions & Answers
Steele Products GG-600N 6000 peak Watts Portable Generator. Can it be converted to electric start?
Question edited for a lot more clarity. There is a video that might help, but there is no conversion kit. What some people do it remove the recoil start and use an impact driver or electric drill with a socket that fits the bolt on the end of the crankshaft. https://www.google.com/search?q=Steele+GG600N+generator+convert+to+electric+start
10/29/2023 10:53:06 PM • Electric... • Answered on Oct 29, 2023
2answers
Whats wrong with my electric hot water heater 240v single element
It requires a 2 pole ganged breaker to meet code and guarantee the breaker is on two legs of the single split phase service. That in itself doesn't explain the 120 volts at the heater element.
Replace the two single breakers with the appropriate 2 pole ganged breaker. Before connecting the feed to the heater, turn on the ganged breaker and measure voltage across the breaker. If not 240VAC then there is a problem at the breaker panel.
If there's 240 at the breaker then you've somehow wired the thermostat incorrectly but can't imagine what you did.
12/8/2022 2:04:39 PM • Electric... • Answered on Dec 08, 2022
Australian "Total Tools" Powerchief 6500CGL electric start generator manual
This is probably close enough. You planned maintenance will also need a full carburettor strip down and clean. count the turns on jetting screws. Screw IN and count the turns to a gentle stop say 2 1/4 turns, then remove and clean with carburettor spray. The float valve in the bottom is likely to be glued shut. https://www.baldor.com/Shared/manuals/2412-404.pdf https://www.google.com/search?q=%22Powerchief%22+6500+CL+manual ..
5/14/2022 10:37:31 PM • Electric... • Answered on May 14, 2022
2answers
Can an electric starter be installed on a Troy Built 5550 watt generator model # 030245?
It may be possible but parts alone would make it cost prohibitive.
It would require a flywheel, alternator, rectifier, starter, battery, ignition switch, cables, and misc. plus labor.
3/3/2022 12:53:12 PM • Electric... • Answered on Mar 03, 2022
Have a 8000 watt etq generator. Automatic idle control doesn't work when switched on .....10 hrs run time on it ....used to work....does not have electric start
There is a board that controls that where the outlets ect is located at
1/24/2022 12:54:48 AM • Electric... • Answered on Jan 24, 2022
My etq tg7000 has electric start. should the battery be charging when the generator is running. The battery on ours does not.
Normally there is a protection fuse between the low voltage charge winding and the regulator, that may be blown if the battery voltage does not hovver at about 13.8 volts when running otherwise the regulator itself may be faulty. A standard small battery charger runnibg off the power will keep you going until it is repaired.
10/2/2021 7:00:31 AM • Electric... • Answered on Oct 02, 2021
Where is the circuit breaker on a electric cooker
cookers usually use a thermal fuse close to the heating element fuses range from 150c to 190c.once you find the fuse check it with an ohmeter it should have continuty. the thermal value should be printed on the fuse.
9/7/2021 5:32:59 AM • Electric... • Answered on Sep 07, 2021
Why does my 27gal powermate smell like electric fire as soon as I turn it over?
Likely a motor capacitor is failing causing excess current (heat) in the motor windings. Does the motor get hot?
OR, a poor connection in the motor start or run circuit either at the centrifugal switch or the capacitors. A loose connection may overheat and emit a burnt resin odor.
Regardless, you'll want to fix it ASAP as it will likely only get worse resulting in higher repair cost.
8/8/2021 9:00:58 PM • Electric... • Answered on Aug 08, 2021
2answers
My Wizard 2 electric fence energiser is pulsing but the lights are not going up and down
check out put with meter or tester - check connections and ground --check line for break or debris
7/5/2021 6:32:51 PM • Electric... • Answered on Jul 05, 2021
Two electric chainsaws, 10" and 16" used without a problem. Now both a blowing a regular single pole breaker.Tried a different breaker the same result.
When you say breaker, presumably you refer to an RCD? The residual current device will trip if the amount of current in the hot wire does not equal the amount of current in the neutral or return wire. This means some current is leaking away which means the chainsaws might have developed a potentially dangerous fault or might just be the result of an excess of damp sawdust entering the motor housing through the vents - or damp has entered the tools by other means. I find a compressed airline useful for keeping power tools internally clean and dry.
2/10/2020 1:31:41 AM • Electric... • Answered on Feb 10, 2020
3answers
I have an electric furnace my 2 pole 90 amp breaker shorted out I was wondering if I could use a 2 pole 100 amp instead
You need to use rated breaker and did you find a fault for why the breaker shorted?
12/21/2019 4:33:12 AM • Electric... • Answered on Dec 21, 2019
What size cicut breaker is in the electric windows ?
In the electric windows of - what - ?
11/28/2019 5:55:08 PM • Electric... • Answered on Nov 28, 2019
MODEL LV812PR Photo electric switch! How to Wire this device? And, can this device handle 110 wall power?
It cannot be connected to 120 volt ... this is a 12 volt photoeye that integrates into the screw terminals on power pack. Following link has some basic information for connecting the photoeye http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
10/28/2019 5:18:30 AM • Electric... • Answered on Oct 28, 2019
How fo i cannect 5,12 voot batteries plus breaker to make it 60 volt for my electric scootet
Connecting 12 batteries in series would give slightly more than 61 volts. Considering that under load voltage will drop then it should be ok. Breaker goes between battery and motor on positive wire.
10/14/2019 4:06:18 PM • Electric... • Answered on Oct 14, 2019
Clarke generator ig 2200kw bought new its worked fine 2 years my problem no electric no lights on thanks
Hi! We help people repair their Clarke Generators. You can find testing procedures here: https://www.generatorguru.com/contact-us/ We also hold all the parts possible for all the Clarke Generators and have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/ Parts Spares for Generators and Small Engine Machinery image-yvhi3wxpq4zyabcrzo2wizws-5-0_0.jpg
9/13/2019 11:10:29 AM • Electric... • Answered on Sep 13, 2019
3answers
The garage gfci reset button won't reset to get electric back on
either short or failure of gfci
6/8/2019 10:44:39 PM • Electric... • Answered on Jun 08, 2019
tip
Repair broken power cord
I have a 50-ft power cord for my electric pole saw. In an accident, the saw cut the power cord. It's long cable and I want to save it. My method keeps the cable lean and retain it's strength. It's not water-proof, but I never use a pole saw in a rainy day.
on May 31, 2019 • Electrical Supplies
Electric Fuji  Cp32fm Circuit Breaker Logo
0 questions posted
Top Electrical Supplies Experts
vince
NOEL
NOEL
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
Electric Electrical Supplies
  • Electric Electrical Supplies
Most Popular Question
whats wrong electric hot water heater
