20 Most Recent
Electric Fuji Sa33b 15a Circuit Breaker Questions & Answers
In order to satisify City Codes I need to have
Are you sure you have correct number? Here is a link to an online cataloghttp://www.fujielectric.com/fecoa/pdf/mccb_pdf/USEH605a.pdf
The ones in this catalog are UL listed. If your number is correct, it may be an import that is in fact not UL listed. Contact Fugi direct to clarify.http: //www.fujielectric.com
Whats wrong with my electric hot water heater 240v single element
It requires a 2 pole ganged breaker to meet code and guarantee the breaker is on two legs of the single split phase service. That in itself doesn't explain the 120 volts at the heater element.
Replace the two single breakers with the appropriate 2 pole ganged breaker. Before connecting the feed to the heater, turn on the ganged breaker and measure voltage across the breaker. If not 240VAC then there is a problem at the breaker panel.
If there's 240 at the breaker then you've somehow wired the thermostat incorrectly but can't imagine what you did.
12/8/2022 2:04:39 PM •
Electric...
Answered
on Dec 08, 2022
Where is the circuit breaker on a electric cooker
cookers usually use a thermal fuse close to the heating element fuses range from 150c to 190c.once you find the fuse check it with an ohmeter it should have continuty. the thermal value should be printed on the fuse.
9/7/2021 5:32:59 AM •
Electric...
Answered
on Sep 07, 2021
Why does my 27gal powermate smell like electric fire as soon as I turn it over?
Likely a motor capacitor is failing causing excess current (heat) in the motor windings. Does the motor get hot?
OR, a poor connection in the motor start or run circuit either at the centrifugal switch or the capacitors. A loose connection may overheat and emit a burnt resin odor.
Regardless, you'll want to fix it ASAP as it will likely only get worse resulting in higher repair cost.
8/8/2021 9:00:58 PM •
Electric...
Answered
on Aug 08, 2021
