20 Most Recent
Puma Air Air Compressors Puma Air PK6060V Professional Vertical Air Compressor - 60 Gallon Questions & Answers
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
