20 Most Recent
Black & Decker Infuze APP VB100 Coffee Maker Questions & Answers
I have black & decker pw1400s it is possible to connect the water faucet
It will depend on what kind of faucet it is. You can get adapters for the faucet on your kitchen sink but I find they are not very good for pressure washers. They can leak and spray water all over your sink and kitchen. For a pressure washer it is best to have an outside faucet fitted. This will give you the correct type of faucet to connect to and a good supply of water to the pressure washer.
It is usually not very expensive to get one fitted.
Black & Decker CM1609 keeps shutting off in the middle of making coffee
I had my black& Decker for about 6 months or so and it started shutting off after a minute or two of brewing. I cleaned it by running 5 cups white vinagar through it twice and using a filter in basket. Then running 2 pots of clean water through. I had to keep turning it on but by they end of later last pot of water rinse it stay on all they way through .there was an incredible about of lime built up . try it worked for me.
Model CM1609 received as a gift 2 months ago. From
I would not have waited this long to get a warranty replacement. If you need the proof of purchase, you will have to ask the person who gifted you. Hopefully, the giver will be understanding and help you out.
Trying to figure out how to turn off buzzer indicator on black & Decker Smart Brew coffee maker.
You cannot turn off beeping but i have found a 'hack' to do so if you are desperate, instead of caulking i would reccomend just simple blue tack/white tack...easier and also removable.
"Now if you want to squelch that beeping (this will probably void the warranty)...You can take off the bottom of the unit (but be advised you need a special screwdriver on one of the screws hidden under the rubber feet).
You will see a circuit board held by nylon standoffs, once you get the board loose you will see a round black unit with a hole in the top side, this is the beeper. To lower the volume so you can barely hear it fill the hole with caulking or silicone and reassemble. (be careful not to pinch any wires....Good Luck....."
STOP THAT BEEPING
