20 Most Recent
Black & Decker Brew N Go DCM18 Coffee Maker Questions & Answers
I fill the Brew and
It sounds like the valve [ball?] at the bottom of your reservoir is sticking. That will prevent good water flow into the heating chamber. Hence, the thermostat trips and shuts off the brew element. Try running undiluted vinegar [without coffee in the basket] to see if this cleans the valve. Also try turning the maker upside down over the sink when the cycle stops, to "backwash" the valve with the vinegar. You may have to repeat this several times.
Coffee pot spills when pouring
This is a back flow problem.
the pressure of the fluid being push by air.
the small lip on the pot can't handle the flow.
go with a small tilt and you should be fine.
Black decker user manuals
Do a web search and type Black and Decker manuals into the box. Most companies post pdf copies of all their manuals on line. This saves them the trouble of having to send them to you.
I need a replacement DCM18 reusable filter
Filters for these and the earlier model are still available, if you dig deep on the internet (the part number is 175181-00, Fits Models: DCM7, DCM18) but the prices plus shipping are as much or more than a new complete machine. I have found the entire unit for around $15 or so. Shop around and buy a new one......
Put waster into reservoir and it does not empty into cup
Would you care to tell us where it DOES go? Which "cup?" It's not clear exactly what your problem is. If it simply stays in the reservoir, that's one problem. If it goes into the coffee, but doesn't drain down to the cup, that's another. If it's the latter, try cleaning out the tiny drain hole with a tooth pick, since it may just be plugged.
