20 Most Recent
Orbit 57882 9 Station Super Dial Irrigation Timer Questions & Answers
Manual test does not work Looks like it does but
If the manual test doesn't work, I think the auto function won't work either. If that is true, your timer is running on the battery and there is no power. Remove the battery and see if it appears to be working. If not, check your outlet to ensure that there is 120 volts ac. Plug a light or shaver into the outlet. If the outlet is good and the clock has no power when the transformer is plugged, you probably need a new transformer.
Gary
Valves don't operate
Unknown if this is new installation, or old installation that stopped working.Clean waterway inside timer with white vinegar?Change batteries?Reset and reprogram timerMost timers have 1 year limited warranty against defects in workmanship.Expected lifespan for battery-operated water timer can be 6 months to 5 years. There are no replacement parts.Complicated digital timers can stop working for variety of reasons.Buy another timer.Copy following link to download manuals for several brands water timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
