20 Most Recent TORK Digital Interval Timer Ssa100r-24 Questions & Answers
2answers
I have a germanian timer that its manual is in
I don't know this timer. I found one image that shows a 5-button timer that I'm not familiar with.
1) Add a comment and describe timer in detail and I will try to match description with my files on timers.
2) Look at following link to see if your timer appears, and then add a comment and I will answer.
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) When I have a manual in foreign language, which is frequently, I use google translate.
http://translate.google.com/#
How to use google translate for timer manuals:
a) Enter entire sentences into translator and it recognizes the language. Then select language you want to translate into. Then press translate button.
b) Copy-paste translation into a document so you can read the information several times while working to set timer.
c) With patience, you can figure out the timer, and then change your document wording so you have digital copy of manual for your records.
Turn your manual into cash:
d) Post your english-version manual on your website, or on Imgur.com. Add a comment on fixya and tell us the web location of your manual. Then others with same question will have answer. Some will be able to get answer for free, others will pay for the answer.
e) Post your manual for sale on your website, and others can buy it and sell it on their website to other folks who are willing to pay for answer.
f) Join fixya as an expert and sell your manuals and knowledge to other folk.
g) Sell timer on your website, and advertise english/german instructions.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
9/22/2022 12:33:12 PM • TORK Digital... • Answered on Sep 22, 2022
The Off tripper does not switch timer clock off
The pins trip a switch behind the dial, you can't see them. Don't worry they will trip the switch and turn and off. Just slide them on the edge of the time dial where you want to go on and off and tighten. If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
12/5/2013 2:44:22 AM • TORK Digital... • Answered on Dec 05, 2013
Instructions for brinks timer 42-1005
Pull all push tabs up.Turn dial to current time by grabbing push tabs and turning dial clockwise. This requires considerable force.Push down tabs for all the time(s) you want the device powered. This timer will only power a device if a tab is down.Good for 15 amps resistive or 1/3 hp motor (inductive load).
7/23/2012 10:48:26 PM • TORK Digital... • Answered on Jul 23, 2012
How tio wire a tork model ejwt timer
Tork EJWT is percentage cycle timer that was formerly manufactured by Paragon and sold as the Paragon E500 series interval (cycle) timerCopy following link for clear Tork EJWT wiring illustrationhttp://waterheatertimer.org/Tork-timers-and-manuals.html#cycle-timer If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/21/2012 3:30:57 AM • TORK Digital... • Answered on Jul 21, 2012
Wireing a tork clock timer
Following link shows Tork timers and manuals, with wiring diagrams:
1/23/2011 7:11:55 AM • TORK Digital... • Answered on Jan 23, 2011
Timer keeps time, but sticks at tripper points
1) Clock motor needs replacement:
Link below shows timer and wiring manuals.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
2) 120Volt Clock motor sells for $43 at Frontier lighting
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&ID=,Photo.Cells...Time.Controls,Replacement.Motors
3) New Tork 1103 sells for $55. Just swap out insides without changing box.
4) Intermatic crossover for Tork 1103 shows Intermatic T103 timer.
Amazon sells T103 for $50
http://www.amazon.com/Intermatic-T103-120-Volt-Mechanical-Switch/dp/B000LDIDBY
1/23/2011 7:08:59 AM • TORK Digital... • Answered on Jan 23, 2011
I don't know how to set the timer to come on a 7
See T1100 Tork timer on following link:
To set this timer, rotate clock dial clockwise until current time lines up with the word 'TIME' located at 5 o'clock position.
Place black and gold P47 trippers at times you want timer to turn on-and-off.
As time passes, the dial rotates. ON tripper flips a lever that turns Load ON, and then later, the OFF tripper flips same lever and turns Load OFF.
1/23/2011 6:57:55 AM • TORK Digital... • Answered on Jan 23, 2011
I am replacing an old Tork mechanical Light
Tork timers are each a bit different depending on voltage and model number.
Each timer has a model number on inside of timer door.
1) Add a comment with model numbers for each timer, and voltage you are working with, and I will post the conversion wiring.
2) Also look up your model number and wiring diagram on following link.
1/23/2011 6:51:48 AM • TORK Digital... • Answered on Jan 23, 2011
I have a tork 1103 electromechanical switch. its working but wont
T1103 can be wired many ways.
T1103 has 240V clock motor.
You are connecting 240Volt pool pump to timer.
Open link below and see wiring diagram: look at bottom left diagram:
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
Electricians don't guess, they test.
Turn power off and separate wires for testing.
Tape tester leads to wood sticks to keep hands away from power.
Stand on dry boards. Wear dry clothes.
Do not touch anything metal.
Turn power ON.
Test each wire to bare ground wire.
For 240V circuit, two different wires should light up tester. Working from your description, by code, these wires should be black and red.
Each of these wires is Hot wire.
These are called Line wires, wires going to pump are called Load wires.
Hot wires connect to terminals L and 1. This will power the clock motor and dial will rotate as time passes, assuming clock motor is good.
Hots are identified.
Test one of the hot wires to remaining wire, and not to bare ground.
Tester lights up on Neutral wire. This should be white wire.
Double check that Neutral wire did not light up on bare ground.
Neutral is not connected to any 1103 terminal.
Remaining wires go to Load (pool pump).
By code, assuming Hot Lines are Red and Black, the Red & Black Load wires connect to X terminal and 2 terminal, in either order. One wire on each terminal.
White wire connects to Neutral wire and is covered with wire nut.
1/23/2011 6:46:47 AM • TORK Digital... • Answered on Jan 23, 2011
I have a 15 yr old tork 1101 pool timer. I
1) Tork P47 tripper is correct tripper for 1101 timer.
Trippers are brass-colored and black-colored.
If they do not fit timer dial you might need new timer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
2) Buy new 120Volt indoor/non-weathertight Tork T1011
To identify timer for sure:
3) Google search Tork 1101 shows timer cost $83
4) Intermatic cross reference shows replacement is T-101 indoor/non-weathertight
Amaxon sells T101 for 43$:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
5) Raintight/outdoor: Aplus and Lowes sell raintight outdoor T-101R for $71
http://www.lowes.com/pd_29405-251-T101RD89_0_
http://www.aplussupply.com/intermatic/timer.htm
6) Cross over wiring.
Tork terminal X is T101 terminal A
Tork terminal 1&L are T101 terminal 1
Tork terminal 2 is T101 terminal 2
1/23/2011 6:13:30 AM • TORK Digital... • Answered on Jan 23, 2011
Instructions for programming a Brinks model #
Manual is shown on links below:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1030-manual.pdf
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
1/19/2011 12:01:41 PM • TORK Digital... • Answered on Jan 19, 2011
Not sure how to wire my Tork 1103 timer
The L terminal would be for your "hot" incoming black wire. The X terminal would be for your load outgoing black wire. Connect both white neutral wires to the blank terminal (notice this feeds the timer motor. The other two terminals (1&2) are not necessary if it is a 110V single circuit.
11/26/2010 11:18:14 PM • TORK Digital... • Answered on Nov 26, 2010
I have a Tork 806A timer, but no instructions on
Tork 806A: There are 6 outlets. Bottom two outlets are always on. Top four outlets controlled by timer all four outlets turn on and off at same time.
Load: Total load on all 6 plugs cannot exceed 1500 Watts, which is typical for 15A circuits. Indoor wall plugs are 15A. Don't add more load to timer than you would put on ordinary wall plug.
Set Time: Rotate dial clockwise to set time. On face of dial, Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} push tabs down to turn on loads, pull them up to turn off loads.
Reset: Timer has reset button in top left corner.
9/20/2010 10:49:50 AM • TORK Digital... • Answered on Sep 20, 2010
I wired a TORK #1103 - hot (black) from the panel
If you look at your diagram, the neutral connects to the box with no number on it. This also supplies the nuetral to the timer motor. There is no need to switch the neutral conductor (white)
Connect line (incoming hot) to terminal L connect the load(black) out to the GCI on terminal X. Put both neutral white wires on the terminal with the square box.(this terminal should have the other timer motor wire already connected to it.
8/11/2010 1:00:31 PM • TORK Digital... • Answered on Aug 11, 2010
I just took over an old building with three Tork
Here's a link to the Tork website. The model timer you have is a past model. The manuals are listed in the technical library.
The model you have is most likely either EW101A SERIES or EW101SA SERIES
See the library for details: http://tork.com/techlib.aspx
7/30/2010 4:55:52 PM • TORK Digital... • Answered on Jul 30, 2010
Where can i find a clock motor for a tork clock.
You will have to call Tork there # 914-664-3542. They are in New York.
10/4/2009 10:11:32 PM • TORK Digital... • Answered on Oct 04, 2009
Tork timer 1103 will not trip off unless lever is
The timer should have came with a dark and light colored tabs. they must be put exactly on the rail that goes in a circle with the time on it.
4/13/2009 3:44:50 AM • TORK Digital... • Answered on Apr 13, 2009
Tork RZ307 Automatic Lighting Timer . . .
Edited 'Trok' to 'Tork'. Then with the right maker, we can find the Tork Timer Category. Also added (what it is). It is new, it is under warranty, take it back for free replacement. If you fiddle with it, you void that warranty/ The only thing you can try is cutting the power at the breaker for 5 minutes. If that doesn't work, disconnect it for 3 days as it has a 2 day backup. See if there is a battery compartment with a dead bulging capacitor in it. Power Outage Backup: Permanent schedule retention with memory module. Supercapacitor provides 2 days of real time backup. http://www.nsiindustries.com/catalog/nsiproducts/tork/tork-digital-time-switches/in-wall-and-plug-in-timers/rz307 https://www.google.com/search?q=Tork+RZ307 ..
4/9/2024 9:48:14 AM • TORK Hardware &... • Answered on Apr 09, 2024
NEED INSTRUCTION MANUEL FOR TORK DZS 100 TIMER
contact tork @ 888-500-4598 they can get you one and it may be available online at their web site??
2/28/2024 12:11:37 AM • TORK Hardware &... • Answered on Feb 28, 2024
TORK Digital Interval Timer Ssa100r-24 Logo
29 questions posted
Top TORK Hardware & Accessories Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • TORK Hardware & Accessories
Most Popular Question
instructions brinks timer 42 1005
  • Hardware & Accessories
