20 Most Recent
Black & Decker ProFinish X750 Iron Questions & Answers
My Pro Finish 714 cord
Thank you for using FixYa. Is the cord cut near the iron end or the outlet end? could the cord be shortened? A new cord can be purchased at most reasonable hardware stores and with a little care and attention can be replaced yourself.
Hope this has been of some help.
How to clean the plate
you can take the solution for descaling coffee machines and set the iron in a layer of less the 1/4 inch deep.
you can clean out the holes with a needle. than run the selfcleaning cycle.
leave the sole in for about 15 minutes. Than clean with non scratching scotch brite.
Why do people smoke
Managing unpleasant feelings such as stress, depression, loneliness, , and anxiety are some of the most common reasons why adults smoke. When you have a bad day, it can seem like cigarettes are your only friend. if you facing while quitting smoking then you can consult some good psychologist who can help you in this situation.
https://www.lybrate.com/indore/psychologist
How to Turn black & decker iron on
at the temp control switch or at the wall socket
if the control switch makes no difference and the wall socket has power , junk the iron
