20 Most Recent
Black & Decker HandyMixer 9220 Mixer Questions & Answers
I have a black and
I find no current sources for that battery pack.
41B030AC18301 9724
I believe this is a two cell lithium assembly for 2.4V. If your handy and can open the pack without damage it may be possible to get replacement cells and rebuild the pack.
Need to replace NiCad for 9220
If you have checked with B&D and the battery supply warehouses on line you could try this if you are good with a soldering iron and really want to keep the mixer going. In the past when I could not get a battery pack for a unit and didn't want to give up on it I have opened up the pack and replaced the batts with new units which are readily available from electronic supply sources such as MCM Electronics or Tritronics Inc. You just have to make sure you get the same size and capacity cells as well as the same type (ie NiCd, NiMH, etc) with solder tabs. Aother resource would be www.batteriesamerica.com. This has helped me get units going more than once. Good luck.
REPLACEMENT BEATERS FOR CAMFIELD POWER MIX
This is so weird. I have the exact same serial number for my Camfield mixer with the same model (I'm guessing from about 1955-57). I wonder if they just put the same serial number on for products created at the same time. I thought 6404 was really low. Did you ever find replacement beaters? Mine have rusted. This was my mother's mixer and I just have a fond place in my heart for it.
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Need replacement beaters for model 106708
First I would check the yellow pages or my chamber of commerce
for a reputable dealer or repair station. If that doesn't work, try
https://www.ereplacementparts.com
