20 Most Recent
Black & Decker MX50 PowerPro® Mixer Questions & Answers
Nylon gears stripped on hand mixer beater gears
Unfortunately, modern small appliances are considered "disposable" by the industry. So there are no "better made" parts. The best you can hope for are the same as what was originally installed. Try https://www.ereplacementparts.com
How to disassemble Black & Decker MX50 PowerPro Mixer
You can remove the handle-back by gently prying the rear clips down and away. But the problem is the power boost button; it has a fork that goes down the left side and snaps over a micro-switch. You need to get that off since there is not room for all 3 buttons (eject, variable speed, and boost) to slide through the handle. A small probe inserted from the top and pushing on the left side to the rear might do it. Or just pry the boost switch upwards; that's how I got mine apart. My problem was the boost microswitch was bad and provided a poor connection. As a result, the beater only ran intermittently on regular switch positions. I solved it by bypassing the boost micro switch. The beater now only runs on the regular speeds but that's fine by me.
REPLACEMENT BEATERS FOR CAMFIELD POWER MIX
This is so weird. I have the exact same serial number for my Camfield mixer with the same model (I'm guessing from about 1955-57). I wonder if they just put the same serial number on for products created at the same time. I thought 6404 was really low. Did you ever find replacement beaters? Mine have rusted. This was my mother's mixer and I just have a fond place in my heart for it.
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Need replacement beaters for model 106708
First I would check the yellow pages or my chamber of commerce
for a reputable dealer or repair station. If that doesn't work, try
