20 Most Recent SanDisk Cruzer Blade - USB flash drive - 16 GB Questions & Answers
How to format write protected SanDisk Blade Micro 16GB USB 2.0 Flash Drive?
i have SanDisk 16 GB Flash it's write protected kindly advice how to remove the write protected from my USB flash. your kind advice will highly appreciate
5/4/2019 8:51:32 AM • SanDisk Cruzer... • Answered on May 04, 2019
The target location on my usb is C:\Windows\system32\rundll32.exe ~$WBWHLJ.FAT32,_ldr@16 desktop.ini RET TLS " "? How to fix this?
hi i think you are missing a file called rundll32its in windows location like this C:\Windows\System32see herehttp://ccm.net/forum/affich-693153-my-removable-device-shortcut-virus
1/15/2018 4:20:29 PM • SanDisk Cruzer... • Answered on Jan 15, 2018
Windows won't recognize the flash drive as a removeable drive
Your laptop may need drivers installed for your flash drive. Visit your USB drive manufacturer's website, find the "Support" page, and download the drivers for your specific drive. Be sure to know what version of your operating system you are running as it may be necessary to ensure you get compatible drivers. Install the drivers and try again.
11/26/2014 9:17:56 PM • SanDisk Cruzer... • Answered on Nov 26, 2014
Why cant i open picture, message no application found?
the file you are trying to open cannot find compatible software on your computer to open it with. This may be a problem with file association in Windows though. If it's a typical JPG or BMP, Windows should have no problem with it. Do you know what type of image format you are trying to open? You can right-click on the file and select Properties to finsd out more information about the file.
11/26/2014 8:37:04 PM • SanDisk Cruzer... • Answered on Nov 26, 2014
4answers
How to remove copy protected error
Look for Unlock switch. Try RMPrepUSB - Drive - Clear Read only status.
9/4/2014 7:48:43 AM • SanDisk Cruzer... • Answered on Sep 04, 2014
How can I have it be reconized?
Need more details: What computer and what operating system? What is the capacity of the memory card and the USB Flash Drive? Are you using the computer's built in card reader or an external one? If the computer is older, or you are using an older operating system, it may not recognize higher capacity cards, and you may need to buy a higher capacity card reader.
5/16/2014 1:50:27 PM • SanDisk Cruzer... • Answered on May 16, 2014
I dont kow how to use a flash drive
Easy put it in, drag files you want to it and eject. then insert to other comp and drag files you want out then eject.
1/29/2014 5:25:22 PM • SanDisk Cruzer... • Answered on Jan 29, 2014
Sandisk cruzer not playing music and videos on car stereo
turn the radio off then go into the menu and configure blue tooth and wifi to on. with radio and device on set device to discoverable. have radio scan for new devices and pair with code.
1/28/2014 8:17:31 PM • SanDisk Cruzer... • Answered on Jan 28, 2014
System cannot find file specified
your memory card has bad sectors that needs fixing by typing chkdsk x: /f /r (where x is the memory card) at the command prompt on your pc/laptop
1/1/2014 12:26:53 AM • SanDisk Cruzer... • Answered on Jan 01, 2014
How to remove usbenter secrity software , even i
To uninstall the application go to the Settings of your android phone. Select Applications>Manage Application. Locate and select SanDisk Memory Zone from the list of all the applications installed on your phone. Select Uninstall and the application will be removed from your phone.
12/25/2013 11:02:44 AM • SanDisk Cruzer... • Answered on Dec 25, 2013
DEVICE NOT ACCEPET FORMAT
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
12/24/2013 7:17:50 PM • SanDisk Cruzer... • Answered on Dec 24, 2013
How to claim our warranty ?
To make a warranty claim please contact SanDisk at the telephone number in the table or [email protected] within the Warranty Period and provide proof of purchase (showing date and place of purchase and name of the reseller) and product name, type and number. You may return the product after first obtaining a Return Material Authorization number and following any other guidelines listed. For further information see www.sandisk.com and select "support".
12/24/2013 6:02:14 PM • SanDisk Cruzer... • Answered on Dec 24, 2013
I have a usb flash memory LG and not fomated at
Use RMPrepUSB.
11/1/2013 9:19:09 AM • SanDisk Cruzer... • Answered on Nov 01, 2013
I want to be able to listen to music in my car using my USB Sandisk Cruzer but my car only accepts an iPhone plug into an Aux hole. Is there anyway I can by pass this
You might be able to using one of these usb to audio lead you can also get these just as adaptors without the need to for a lead http://www.ebay.com.au/itm/3-5mm-Jack-Plug-to-USB-Male-MP3-Mp4-Audio-Data-Cable-White-/330831058200?pt=AU_Electronics_Portable_Audio_Accessories&hash=item4d07115518 $4.12 3.5mm Jack Plug to USB Male MP3 Mp4 Audio Data Cable White or http://www.ebay.com.au/itm/USB-Male-to-3-5mm-Audio-Stereo-Headphone-Jack-Plug-Cable-For-MP3-MP4-Black-/160733005608?pt=UK_Computing_Sound_Vision_Audio_Cables_Adapters&hash=item256c6f0728 $1.50 free postage You might get these on Ebay im not sure which country you are in this might guide you to one You could get this on Ebay if you dont have an account you will need to create one. https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also Add your Postal Adress also Add a PayPal account. Click on the Ebay tab on top of page from the drop down list you will see specific pages. On left hand side on Ebay summary page you will see the PayPal link. when you get to the PayPal login page at the bottom you will see new to paypal sign up tab. Paypal to create an account PayPal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a Postal Adress. Be very specific when you type in the search. Always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. Music has become more mobile than ever before, as numerous devices can store and play music on-the-go. Companies have developed car audio decks that incorporate USB ports in the faceplate. This allows flash drives to be plugged into the deck, and music on the drive to be played. Flash drive format issues are minimal, considering nearly all flash drives are formatted in the FAT32 file system by default. FAT32 is readable by any operating system, or stereo deck with a USB por Determine if the stereo deck in the vehicle is capable of playing music off a USB flash drive. Read the stereo deck user's manual, or inspect the deck faceplate for a USB port. Plug a USB flash drive into an available USB port on a computer. Check the drive to make sure there is enough available space for music files. Using Windows, double-click the desktop icon labeled "My Computer." Right-click the flash drive icon, and select "Properties." Capacity will be shown. Using Mac, click the flash drive icon once it appears on the desktop. Click "File" in the top menu bar, then click "Get Info." A dialog box appears, and capacity is listed. Drag and drop any desired music files onto the flash drive. Be sure the files are in .mp3 format. Although some stereo decks are capable of playing other music types, the .mp3 extension is universal and all decks will play it. Spend a short amount of time organizing the files into folders. Organize by genre, artist, or create mixed playlists. Selecting music while driving will become much less distracting. Close the drive window, and safely eject the flash drive from the computer. Plug the flash drive into the stereo deck of the vehicle. Select the USB port as the music source, via the stereo deck. Read the manufacturer's user manual if unsure of how to change the source. Adjust the volume, listen, and enjoy. Hope this helps.
1/22/2013 10:36:04 PM • SanDisk Cruzer... • Answered on Jan 22, 2013
Sandisk cruzer firmware
Click on the "Start" button and then type "Update" into the search box. Click on "Windows Update" in the box that appears. Click on "Check for updates" and wait for the updater to scan your system. Click on the firmware update, if there is one. If your scan disk firmware is up-to-date on the right firmware, there will not be an update. Click "Install Updates" if you have an update available to you and then click "Finish" when it is complete. Restart your computer.
1/21/2013 11:34:35 PM • SanDisk Cruzer... • Answered on Jan 21, 2013
Sandisk cruzer protection removal
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. hope this helps you
4/4/2012 3:54:41 AM • SanDisk Cruzer... • Answered on Apr 04, 2012
How to format sandisk cruzer under Win XP
Right-click your Cruzer in "My Computer" and select "Format." Select "NTFS" from the "File system" list and click "OK."
3/7/2012 8:01:09 AM • SanDisk Cruzer... • Answered on Mar 07, 2012
Sandisk ultra write protected
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjijK-2oOeCAxX2k4kEHZN0CnEQrAIoAHoECCQQAQ&url=https%3A%2F%2Fforums.sandisk.com%2Ft%2Fremove-write-protection-from-usb-drive%2F33510&usg=AOvVaw3A01NeRgbLmAWvj17rGaBA&opi=89978449
11/28/2023 5:48:51 PM • SanDisk... • Answered on Nov 28, 2023
Sakar mid 1240512
6/13/2023 5:55:32 PM • SanDisk... • Answered on Jun 13, 2023
SanDisk Cruzer Blade - USB flash drive - 16 GB Logo
1 questions posted
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
Cruzer SanDisk
  • Cruzer SanDisk
Most Popular Question
data recover
  • Electronics - Others
