20 Most Recent
Blackberry Curve 3G 9300 - smartphone - GSM / UMTS Questions & Answers
How do i free up memory-space on my handset?
There are very few app that can be moved to your Micro SD card - So remove some apps that you are not using. Delete all your old inbox messages - clean email send box and inbox that you no longer require. Phone should run better
Blackberry curve 9300 cursor pad not working
They do bad. I would either 1) install latest OS software using a PC and Desktop Manager, and 2) remove/replace battery to see if this fixes your problem. If not, time for another unit.
Forgot password on my blackberry
I`m think the only way to unlock phone is a hard reset (You can loose all data on phone). Below is link for guide: https://hardmasterreset.com/464-2/
How can I install whatsapp on a blackberry 9320 curve?
If it is not available in the BB store(its not) then you need to search for the apk on the internet which you may not find, and if As long as they support android 4.3, it will run on your device with some glitches. that means you need to have 4.3 running on your device. it may be possible however may not be worth what you have to go thru to MAYBE be able to use a crummy version of it. Best of luck
Questions? Just ask
Mr.Mike
https://www.6ya.com/mr.mike
