Hi, if your unit is getting good water pressure then the problem is going to be your flow meter which is the device that measures how much water is coming into the unit. If it doesn't detect enough water coming into the unit, the dishwasher will hault and give you check water light error. When the error comes up look at the water in the bottom and see if you have enough water in the bottom for a cycle. If not then your flow meter is fine and your unit truely isn't getting enough water which means that either your house isn't giving good water pressure to the dishwasher, or the electronic water valve that connects to the water line from your house is bad and needs to be replaced....
The wax plunger is most likely the culprit. Take off the door liner and the wax plunger is a little brown shaped device at the back of the dispenser . get a new one and replace the old one. make sure the dispenser door moves freely first though. it could be gunked up with soap residue.
Check first the filters on the inlet water line (both sides).
Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)).
If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one.
Good luck
Quorahttps://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
JustAnswerhttps://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in.
https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31
DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31
As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet.
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
