20 Most Recent Onan Cummins 12.5 HDKCB/11506 RV QD 12500 Quiet Diesel 12.5kw Generato Questions & Answers
0answers
0answers
Onan quiet diesel 6000 won't crank clicks
Check battery voltage, starter solenoid, then starter motor
2/19/2015 1:33:27 PM • Onan Cummins... • Answered on Feb 19, 2015
Starts and stops
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
2/19/2015 12:47:19 PM • Onan Cummins... • Answered on Feb 19, 2015
I can't find mine, where are thayclean spark
It is a screen on the muffler output, also remove the plug on the bottom of the muffler to remove carbon
2/19/2015 12:52:20 PM • Onan Electrical... • Answered on Feb 19, 2015
Onan 4000 not charging battery
Some Onan 4KW do not have auxiliary battery charge windings and rectifier. Are you sure you have one? If not you will need and external charger
2/19/2015 12:50:20 PM • Onan Electrical... • Answered on Feb 19, 2015
Generator runs fine but quits producing power
Model spec number? be more specific please
2/19/2015 12:49:08 PM • Onan Electrical... • Answered on Feb 19, 2015
What the compression to be on a 2 cylinder onan motor?
Which motor, which generator model and Spec
2/19/2015 12:47:49 PM • Onan Electrical... • Answered on Feb 19, 2015
Onan 12hdkcd error 27 and 13
2/19/2015 12:47:03 PM • Onan Electrical... • Answered on Feb 19, 2015
Onan 2500 camp power ran fine then died & aslong as i held starter switch on it ran fine but stopped when released start switch . after a few days it started up & ran fine for about 30 min. t
You may have dirty rotor slip rings, or bad brushes. Field voltage must be maintained. Check those first
2/19/2015 12:43:02 PM • Onan Electrical... • Answered on Feb 19, 2015
Rv onan rv runs but now makes a rackett when running was real quiet
Contact www.advanced-power-technologies (Cummins Dealer) with exact model and spec number. Also there are cold weather options, and cold weather models. Many people buy the RS units of the net, only to find they have been stuck with warm weather models, and they don't start. Does it show a code, or a code 45.
2/19/2015 12:41:51 PM • Onan Electrical... • Answered on Feb 19, 2015
Idle surges
What model? Please be more specific.
2/19/2015 12:37:34 PM • Onan Electrical... • Answered on Feb 19, 2015
Hard starting
Again, what generator model? Onan have thousands. Be more specific please.
2/19/2015 12:36:43 PM • Onan Electrical... • Answered on Feb 19, 2015
0answers
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Onan Cummins 12.5 HDKCB/11506 RV QD 12500 Quiet Diesel 12.5kw Generato Logo
Popular Tags
4 questions posted
Top Onan Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Onan Electrical Supplies
Most Popular Question
starts stops
  • Electrical Supplies
