20 Most Recent Kohler 35RZG-RES 35 Kw Generator Questions & Answers
The engine is failing to run after a commanded start. Repeatedly.
Kohler... | Answered on Apr 19, 2019
Are there any faults listed on the control display? If display is dark then likely a battery issue. Check battery voltage with a Digital Multi Meter (DMM). It should be at least 12.5VDC.
Kohler... | Answered on Apr 17, 2019
Sounds Like possibly the regulator is the issue.
Flightsystems Can test these to see if it is good or not.
also here is a link for the service manual
https://us.v-cdn.net/5020499/uploads/editor/0c/g1lx13xi2vyy.pdf
Kohler... | Answered on Apr 16, 2019
the parts manual is a tp-5317 which I do not have . You said its a dec2? or a fast response 2? What is the part number off the main circuit board in the control box?
if you have an scr pack, that has 6 pins, there are two for ac, two for gates, and two for the excitation field.
The two gate wires come off your adc controller.
http://www.kohlerpower.com/onlinecatalog/pdf/g2058.pdf
Safety shutdowns:
  1. Loss of coolant
  2. High water temperature
  3. Low oil pressure
Likely one of these. If no indicators at a panel check at the connector.
Kohler... | Answered on Feb 19, 2019
There might be two reasons for the failure of generator auto start.
1. It is the ATS automatic conversion control device that does not issue the start generator command after the mains power failure or phase loss operation, or the self-starting relay failure, which causes the generator to not start itself. This situation is relatively rare.
2. It is the generator start battery failure, and this kind of situation is relatively more.
Kohler... | Answered on Dec 19, 2018
Kohler 35RZG-RES 35 Kw Generator Logo
1 questions posted
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kohler Electrical Supplies
Most Popular Question
kohler 30ryg generator g220 transfer
  • Electrical Supplies
