20 Most Recent Kyocera Rise Sprint Questions & Answers
Switching from Airplane mode to regular?
What type of phone do you have? Giving the brand and model number will help others help you. There are hundreds of phones out there, and they are different. :)
11/29/2014 4:51:40 PM • Kyocera Rise... • Answered on Nov 29, 2014
Camera won't scan barcode
Which barcode scanner app are you using? You could try using a different app if the one you have won't work.
8/15/2014 1:19:08 PM • Kyocera Rise... • Answered on Aug 15, 2014
0answers
2answers
How to bypass a pin code on lock screen on a Kyocera phone
All I can suggest for this is to take it to mobile phone specialist. They will have the tools to help. There is a possibility they will have to do a 'Hard' reset which often mean resetting to phone to factory settings. This means you risk losing your personal information like phone numbers, Photos and stuff you've saved on the phone. Pin codes are a security feature so naturally are hard to bypass.
9/6/2023 8:35:59 PM • Kyocera Cell... • Answered on Sep 06, 2023
Have just purchased a Kyocera cell phone and I need to get it set up - need assistance
Kyocera DuraXV LTE - Activate / Set Up Device
Select a language option then select. Set. ...
On the Full Readout screen, select an option then select. Set. ...
On the "Phone activation" screen, Verify the 10-digit mobile phone number then press the. ...
On the "Verizon Cloud" screen, press the. ...
On the "Ready to go" screeen, select.
3/11/2023 8:30:22 PM • Kyocera Cell... • Answered on Mar 11, 2023
Kyocera e4810 with which carriers
The Kyocera E4810 is also known as the Kyocera DuraForce Pro 2 and it is compatible with a variety of carriers in the United States, including:
  • Verizon
  • AT&T
  • T-Mobile
  • Sprint
  • U.S. Cellular
However, it's important to note that some carrier-specific features may not work if you're using the phone with a carrier it was not originally designed for. Regarding the issues you're experiencing with Tracfone, it's possible that the phone may not be compatible with their network or there may be a configuration issue. You may want to contact Tracfone customer support or visit a Tracfone retail store to see if they can assist you with getting the phone to work on their network
3/4/2023 8:38:50 AM • Kyocera Cell... • Answered on Mar 04, 2023
2answers
Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings > Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547 If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
9/19/2022 1:44:58 PM • Kyocera Cell... • Answered on Sep 19, 2022
My Kyocera Duraforce phone overheats and shuts down when the temperature is over 85 degrees. I can restart it but it shuts down again.
Question edited for clarity Duroforce . DurAforce. Question moved from Cara and Trucks. It appears to be a know issue. https://www.google.com/search?q=Kyocera+Duraforce+phone+overheat ..
7/22/2022 4:14:29 PM • Kyocera Cell... • Answered on Jul 22, 2022
2answers
My instagram not working on my android
This happened with facebook on my android. First try resetting your phone (turn completely off then back on). If that does not work go to settings and completely uninstall Instagram. Go to play center and re download it.
5/27/2022 2:58:36 AM • Kyocera Cell... • Answered on May 27, 2022
Kyocera DuraXV Extreme E4810 Flip Phone. How can I re-enter a phone number that I accidentally placed in call rejection?
Question edited to add FULL make and model name. Remove Block
  1. From the main screen, select Menu. Use the 5-way navigation pad to highlight and the center button to select.
  2. Navigate: Tools and Settings > Settings > Call Settings > Call rejection.
  3. Highlight the contact(s) to remove then press the left soft key to choose Remove.
  4. To confirm, press the left soft key to choose Yes. https://www.verizon.com/support/knowledge-base-214517/ ..
4/30/2022 11:59:06 PM • Kyocera Cell... • Answered on Apr 30, 2022
How do you factory reset a kyocera hydro view C6742 from cricket?
HardReset.info: At the very beginning hold down the Power key in order to switch off the cell phone. HardReset.info: In this step press and hold the Volume Down + Power button for a few seconds. HardReset.info: You should release held keys when the Recovery Mode starts. HardReset.info: Afterwards press Volume Down a few timies to highlight "wipe data/factory reset", and then push the Power button to confirm this option. HardReset.info:
  • Next, select "Yes--delete all user data". Use Volume buttons to scroll and Power rocker to select.
  • HardReset.info: When the Recovery Menu appears once more on the screen, choose "reboot system now".
    12/20/2021 4:29:43 PM • Kyocera Cell... • Answered on Dec 20, 2021
    2answers
    I am looking for a manual for the kyocera qualcomm
    Try turning it on and off, that should stop the beep.
    7/30/2021 4:23:52 AM • Kyocera Cell... • Answered on Jul 30, 2021
    MY KYOCERA DURAFORCE DROPPED IN WATER AND NOW I HAVE A BLACK SCREEN BUT PHONE IS ON
    HAVE HEARD THAT DRY RICE WILL SUCK WATER OUT
    7/12/2021 11:34:56 AM • Kyocera Cell... • Answered on Jul 12, 2021
    Kyocera urbano v02 master reset
    How can i remove pin lock from au urbano v02
    5/5/2021 2:35:37 PM • Kyocera Cell... • Answered on May 05, 2021
    Kyocera Rise Sprint Logo
    18 questions posted
    Top Kyocera Cell Phones Experts
    Jim LeVerso - IT...
    Jim LeVerso - IT...
    john h
    Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
    View Most Popular
    Kyocera Cell Phones
    • Kyocera Cell Phones
    Most Popular Question
    switching from airplane mode regular
    • Cell Phones
