20 Most Recent Belkin AC 1200 DB Wi-Fi Dual-Band AC Gigabit Router Questions & Answers
What color should the light be if connected to my wifi
Belkin Support Phone Number 800-223-5546 Average Wait: 14 mins - Mon-Fri: 9am-9pm
4/4/2015 4:59:37 PM • Belkin AC 1200... • Answered on Apr 04, 2015
Belkin F7D4301 is unavailable in browser
Visit Belkin Official Support - F7D4301 Downloads There are two versions of firmware available. Version 4 and Version 1. To downgrade your router firmware, use version 1 firmware. I hope this will resolve your issue.
9/14/2023 1:27:46 PM • Belkin Computers... • Answered on Sep 14, 2023
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
3/19/2023 8:35:19 PM • Belkin Computers... • Answered on Mar 19, 2023
I cannot connect to the
you need more than a wireless adapter to connect to the internet......
you need a wireless network to connect to. in cafe's and pubs the owner sometimes sets up a WiFi network that their patrons can connect to, however most people have to provide their own.
to get to the internet , you will need.
A broadband connection (ADSL / Cable) this normally comes with a standard NON wifi modem
A WiFi Router (including ADSL / Cable Modem) depending on what you have already.
then to link a remote PC / Laptop to this network, A suitable wireless adapter ( like your belkin adapter)
it is a common misconception that a wireless adapter is all you need (advertising is vague)
7/20/2022 6:29:10 AM • Belkin Computers... • Answered on Jul 20, 2022
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
7/20/2022 6:21:33 AM • Belkin Computers... • Answered on Jul 20, 2022
3answers
How do I Reset my Belkin wifi Extender?
Using the reset button The location of your range extender's reset button will vary depending on its model. The reset begins once you press and hold thereset button for at least 10 seconds while the range extender is powered ON. The Status Light on the the range extender will momentarily flash and will then begin to blink. When the light becomes solid again, the reset is complete. Using the web-based setup page If using the physical button does not work, you can access the range extender's web-based setup page and do the reset from there. Before you begin:
  • Make sure that the wireless computer or device you're using to access the web-based setup page is connected to the same network as the range extender.
  • You need to identify the IP address that your router has assigned to your range extender. Locate this by accessing your router's DHCP Client table. Once you have the range extender's assigned IP address, use it to access your range extender's web-based setup page.
  • Alternatively, you can enter "http://192.168.206.1" in the web browser's Address bar if your range extender has NOT detected a DHCP server in your network.
Step 1: In the web-based setup page of the range extender, go to Utilities and select Restore Factory Defaults. QUICK TIP: You may be prompted to log in with your range extender's administrator password. If you have not set any, simply leave the field blank and click on Submit. Step 2: Click on the Restore Factory Defaults button. Your Belkin range extender should now be restored to its factory default settings.
1/19/2022 12:25:42 PM • Belkin Computers... • Answered on Jan 19, 2022
Drivermax
Routers are very important for setting up an internet connection. As we all know, the Internet is the most important network, which connects us to the world. There are various companies exist in the market, which offers routers. But Belkin is the top market-leading company for routers. Advance features, technology is the attributes of the Belkin router. For a new router user, installation is a big challenge, and in case the user doesn't.have installation CD then it becomes more difficult. So in this blog, we are going to discussHow to Setup Belkin Router Without CD. Now, you do not need to worry about the installation process, There are 2-3 ways to set up Belkin Router Without a CD.Now one question comes to your mind, How? So Tech Support Experts are here to answer all your queries. Our team is experts in technology and here we will elaborate on the steps to Setup Belkin Router Without CD.
8/11/2021 9:42:08 AM • Belkin Computers... • Answered on Aug 11, 2021
How to uninstall belkin security
Scroll down and select your Belkin device's setup utility. This varies by product, but begins with "Belkin" followed by your device type. Click "Uninstall" and enter your Windows administrator password if prompted. Click "OK" to confirm that you wish to uninstall.
How to Uninstall a Belkin Utility
6/10/2021 8:19:04 AM • Belkin Computers... • Answered on Jun 10, 2021
3answers
The modem light wont stop flashing amber
Replace it , they dont last long and often chips go inside them,cheaper to have replaced than repaired.
6/9/2021 8:15:30 AM • Belkin Computers... • Answered on Jun 09, 2021
How do i setup belkin range extender without disc?
you need the software from Belkins website.
5/22/2020 7:09:41 AM • Belkin Computers... • Answered on May 22, 2020
How to fix Belkin Router DNS Error ?
Today Everyone wants a hight internet Speed but when suddenly the internet gets disconnected then this is very frustrating situations. DNS means domain name system Here the solution for ROuters Error: Firstly fix the login page issue. Go to the Internet WAN icon and click on the DNS icon. Go to the Internet WAN Setting where you can access the link. Uncheck the Checkbox near of Automatic from ISP. After the enter DNS address which you want set on Blink Routers.
2/7/2020 7:33:22 AM • Belkin Computers... • Answered on Feb 07, 2020
Youtube spammer as well: https: //www .youtube .com/watch?v=3TiA1Jed7xk
Warning to FixYa readers - DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you. Please only ever use the support contacts from the official company website {edited by volunteer Expert}
11/13/2019 6:27:38 PM • Belkin Computers... • Answered on Nov 13, 2019
Belkin Router tech support pHoNe #{l;844 SCAMMERR 3O~} nUmBeR USA
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
11/12/2019 6:35:56 PM • Belkin Computers... • Answered on Nov 12, 2019
Belkin Router tech support pHoNe #@{l;844SCAMMER 3O~} nUmBeR USA
11/12/2019 6:26:41 PM • Belkin Computers... • Answered on Nov 12, 2019
Belkin AC 1200 DB Wi-Fi Dual-Band AC Gigabit Router Logo
3 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
color light connected wifi
  • Computers & Internet
