20 Most Recent
Bosch SHU9926UC Built-in Dishwasher Questions & Answers
Beeping won't stop at end of cycle
Our Bosch does the same thing, we just open the door shut of the power and close the door again so the heat can sanitize the dishes. I don't recall if there is an alert off button though.
When dishwasher is turned on (regular wash
Do you have any of the lights flashing?
There are two possibilities -
1. the door switch is not sensing close correctly. This will prevent dishwasher from starting.
see
this diagram for location etc. It is item 3.
or
2. you have Aquastop device installed in the inlet water connection which has been triggered due to a leakage. This can prevent water from coming in.
Please post your comment to confirm what you find.
The washer arm that extends
Welcome to FixYa.
In a word...yes, to answer your question. I would also add it shouldn't come off too easily.
If you observe closely on the back wall of the diswasher where the supply tube is mounted you'll see a metal "clip" the tube snaps/fastens to. I'm presently using my iphone, but I can attach an image tomorrow if it isn't clear to you how it fits back in place.
Let me know how it goes or if you need further assistance.
Thanks for choosing FixYa. I'll watch for your reply or post of your progress/results.
Regards,
Macmarkus :)
Bosch dishwasher error code c1
HiPump-out not accomplished in normal time.Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
1/20/2024 2:53:57 AM •
Bosch...
Answered
on Jan 20, 2024
Bosch dishwasher leaking on the back
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
8/27/2023 3:43:43 PM •
Bosch...
Answered
on Aug 27, 2023
I am not getting water into the dishwasher after changing the inlet valve
Check if there is anything in the large item trap or blocking the water level sensor. The dishwasher won't try to fill if it believes it is full. Try pressing and holding the Start button for 3+ seconds. The Clean LED should light up in a minute. If it does, try the on/off button and starting a new cycle. (This just clears any old programs from the memory.) Some washers will stop if they detected a water leak. Sometimes turning off the power for a while and checking for water in the cabinet below the dishwasher or in the motor area is useful.
The more likely items to check: Check the wiring between the inlet valve and the control board. Check the wires for corrosion at the connecting pins and for continuity. Broken conductors don't send a signal to open and close the valve. If those are okay, then the control board itself may be faulty.
Since this dishwasher is discontinued by the manufacturer, I don't know if all of the parts are still available. The only parts list for the SHE3ARL2UC/28 that I found is here:
https://www.partselect.com/Models/SHE3ARL2UC/ . They don't list any wires or the control board.
I hope this helps.
7/9/2023 9:13:29 PM •
Bosch...
Answered
on Jul 09, 2023
Bosch built in microwoven error E 3 how to fiend the problem
If you're seeing an E3 error on your Bosch built-in microwave, it usually indicates an issue with the touchpad or control board. Here are some steps you can take to try to fix the problem:
1. Unplug the microwave: The first step is to unplug the microwave from the electrical outlet for at least a minute. This will reset the control board and may clear the error code.
2. Check the touchpad: Sometimes, the E3 error can be caused by a stuck or malfunctioning touchpad. Check the touchpad for any damage or debris that may be interfering with its operation. Clean the touchpad with a soft, damp cloth and make sure it is completely dry before plugging the microwave back in.
3. Replace the touchpad: If the touchpad is damaged or not working properly, it may need to be replaced. Contact a Bosch authorized service center to order a replacement touchpad and have it installed by a qualified technician.
4. Replace the control board: If the touchpad is not the issue, the E3 error may be caused by a faulty control board. Again, contact a Bosch authorized service center to order a replacement control board and have it installed by a qualified technician.
In any case, if these solutions do not work, it's best to contact a qualified technician to diagnose and repair the issue, as microwave repairs can be dangerous due to the high voltage involved.
4/26/2023 4:42:30 AM •
Bosch...
Answered
on Apr 26, 2023
