20 Most Recent Bosch 23 in. SHU3307UC Built-in Dishwasher Questions & Answers
Water is not draining from
Water is not drying from dish
11/27/2013 6:41:57 AM • Bosch 23 in.... • Answered on Nov 27, 2013
2answers
Dishwasher sounds like it is running, but no water is circulating
also, if water has leaked into the tray below the dishwasher, it won't run.......you'll have ti take off the bottome panel to see
3/10/2013 12:58:36 AM • Bosch 23 in.... • Answered on Mar 10, 2013
My Bosch shu3307uc pumps out all the water at the
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch SHU3307UC dishwasher, correct ? Firther to this you.ve stated "slowly fills the bottom between cycles, even with little or no activity at the sink"
It sounds to me like the fill valve is at fault unfortunately. This is a very common problem for Bosch dishwashers of that era.
A faulty fill valve...sticking in the "open" position either due to the plunger in the coil getting stuck or sediment inside the valve body impeding it from closing correctly...Either way you're safer to change it with the history of these valves failing.
This is what to look for...
As long as your model is indeed a Bosch, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple, if needed. They may be available at your local brick & mortar parts depot/vendors.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in or it's all clear you should be good to go.
Let me know if you need any further assistance. Thanks for choosing FixYa and good luck.
Please take a moment to rate the assistance provided here and a brief testimony on your experience here at FixYa is appreciated as well and tell your friends to look for "Macmarkus" on FixYa should they need asistance as well.
Regards,
Macmarkus :)
9/27/2011 12:18:19 AM • Bosch 23 in.... • Answered on Sep 27, 2011
Dishes and glasses not getting clean. visual
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
3/3/2011 2:07:16 AM • Bosch 23 in.... • Answered on Mar 03, 2011
Dishes and glasses not getting clean. Visaul
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
3/3/2011 1:51:00 AM • Bosch 23 in.... • Answered on Mar 03, 2011
It stopped running and has a smoke smell. It will
Welcome to FixYa.
Based on your post "It stopped running and has a smoke smell. It will not drain or do anything." it may just be a loose/burnt connection in the dishwasher junction box or a severed wire in the door panel.
** I would start by first shutting off the breaker...safety first**
Then removing the kick plate ( access panel at the bottom )...
...and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
Typically this will manifest in just the manner you've described.
If it looks OK there I'd remove the outer door panel ( careful the edges are sharp ) via the six #20 torx head screws...
...check for a severed wire at the pivot point in the door, typically covered in a plastic casing as shown here..
The small plastic blocks which may be present in the bottom corners of the door panel, i.e.
...they can be a pain to re-install, but they do only go in one way, however it is ok to leave them out...their only purpose is to strengthen the structure.
Let me know what you find and I'll try to assist you further if necessary. Thank you for choosing FixYa today for your inquiry.
Regards,
Macmarkus :)
1/9/2011 8:04:00 PM • Bosch 23 in.... • Answered on Jan 09, 2011
I have a Bosch dishwasher
Sorry to read about your problem, I hope this helps you out.
yes you need to get the switch replaced...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/20/2010 11:09:34 PM • Bosch 23 in.... • Answered on Dec 20, 2010
We have a Bosch SHU3307UC dishwasher. Two friends
Put dirty stuff in will eventually keep a tech like me very busy. We love to come and charge you alot for cleaning your dishwasher. Remember the Maytag commercials where they put a cake in it? Still got the dishes clean but before long it will cost you big time. Just run everything under the tap. Pot and pans should be lightly washed also. Watch how you place the dishes. Most dishwashers spray up from the bottom. Block it, and the spray will not reach the top.
11/28/2010 10:09:01 PM • Bosch 23 in.... • Answered on Nov 28, 2010
0answers
When you turn it on the pump kicks on and it pumps
there is a float switch in the base if you tip machine to the left water will trickle out allowing you to reset machine but if it has a leak you will have the problem return until leak found.
5/27/2010 9:30:10 PM • Bosch 23 in.... • Answered on May 27, 2010
My bosch dishwasher is not producing hot water,
THE WATER GOING INTO MACHINE IS NOT HOT. LET WATER RUN UNIT IT IS HOT THEN START THE MACHINE. HEATER ONLY FUNCTION IS TO MAINTAIN THE HEAT , IT DOES NOT GO FROM COLD TO EXTRA HOT
2/28/2010 4:47:07 AM • Bosch 23 in.... • Answered on Feb 28, 2010
Bosch dishwasher S10R1B: Water not pumped out
Normally it is the impeller which is stuck. Take out the dishes and the filters and empty it for water by hand. Yes it is a dirty job. Then at the bottom there is an opening in the steel where the water is collected. Empty this too. At the bottom left there is a torx20 screw that keeps the cover for the impeller. remove the cover and check that the impeller can move. The may be object stuck
You canalso force the safety mechanism in the door with a screwdriver and try to see if the impeller moves when it is supposed to empty water.
My problem is that I did all this but it still does not move. It may be the impeller motor which is broken. To replace that one is not easy.
9/1/2009 9:32:56 PM • Bosch 23 in.... • Answered on Sep 01, 2009
Detergent latch install for Bosch SHU3307UC dishwasher
you need to remove the front panel of the dishwasher. you need to open the door and remove the 6 torx screws on the inside of the door, close the door and lift up and out to remove front panel. you wiil see the detergent assembly there
1/1/2009 2:37:24 AM • Bosch 23 in.... • Answered on Jan 01, 2009
Hi, I have a Bosch
bosch dishwashers will run forever if it can't get the water to 150 degrees. it can't get it there because either the heating element is bad, or the solder joint on the control board that contols the heating element is bad. you can order a new board, of if your mechanically inclined you can take the board out and resolder the bad spot
1/1/2009 2:31:08 AM • Bosch 23 in.... • Answered on Jan 01, 2009
Water remains standing in the tub
take off the filter and there is a screw under the filter remove that screw to see if there is anything in there.that might be a blockage causeing not all the water to drain.
12/30/2008 12:18:42 AM • Bosch 23 in.... • Answered on Dec 30, 2008
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support 1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish... This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ... 9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone. 1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your ..https://www.youtube.com/watch?v=Xr4DBwACUW4
4/15/2024 10:37:04 PM • Bosch... • Answered on Apr 15, 2024
Bosch 23 in. SHU3307UC Built-in Dishwasher Logo
Popular Tags
30 questions posted
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
bosch shu3307uc pumps out all water
  • Dishwashers
