20 Most Recent
Bosch SHU3306UC Built-in Dishwasher Questions & Answers
The dishwasher makes a noise that will not stop until you turn the water supply off.
sounds like the magnetic switch for the water intake has become clogged and not re sealing its self, you would need to remove the water pipe and see if you can see anything in the switch keeping it open, if not then the switch has gone and needs replacing. it can be that there is no filter on the water line and they could of cleaned the water line and a bit of muck from the cleaning the main water lines has got into the washer.
How to remove latch from Bosch SHU3306 dishwasher
A solution to this problem would be to sell me your dishwasher. The law
firm for which I work is looking to acquire an old unrepaired Bosch SHU
33 dishwasher for some ongoing litigation. If you (or anyone else with
this model Bosch) could send me some details regarding your dishwasher,
you may be able simply to buy a whole new dishwasher. My email is
JFraser -at- jshlawmi.com.
Thanks!
Replace Bosch SHU3306UC door panel with stainless steel?
Instead of replacing the entire door.
Go to http://www.applianceart.comThese guys offer every solution imaginable for refacing your existing dishwashers. They make dishwasher covers in a variety of designs, textures, solid colors and stainless. Check out their website and if you still have questions get in touch with these guys. They are able to walk you through all the available options and keep you from having to replace the entire door.
Someone put dishsoap in the dishwasher
Hello jennifer, welcome to fixya.
I usually find this works...
If you have your normal dishwasher detergent such as Cascade, Electrosol etc. add some directly into the tub of the unit as this type of detergent actually has an "anti-sudsing" agent added to it and will neutralize any "soap" introduced to the machine.
Don't be shy with the stuff, be generous it will likely require a couple or a few tablespoons full.
You may need to repeat the process or just add a ton of dishwasher detergent as well as some vegetable oil which will help neutralize the soap as well.
Select a "normal wash" cycle, but monitor it closely. If you notice it sudsing add more detergent and make sure the water is good and hot at your kitchen tap before turning it on.
Let me know how you make out. It usually works in the cases I've had...eventually. I've seen plenty as you are not the first nor will you be the last...that's life ;o)
Please take a moment and rate this solution favorably after experiencing positive result's. Let me know either way please.
Thank you for visiting "fixya" today.
Good luck.
macmarkus :)
