20 Most Recent Bosch 24 in. SHX33A05 Stainless Steel Built-in Dishwasher Questions & Answers
Bosch shx33a starts, fills, then stops. Drains OK when forced to end cycle.
I know this may sound very silly but i had the same problem with mine and all i had to do was pull it out a bit as the drainage pipe at the back was only slightly sqashed against the cupboard but it does matter
4/15/2015 9:07:55 PM • Bosch 24 in.... • Answered on Apr 15, 2015
Drain cycle will not turn off -
pull the machine out and tilt it back, water may pour out from under the machine, if it does, it indicates that the anti-flood device has actuated, thats why the machine is continuing to drain constantly. leak some where underneath is the problem.
pallesappliancerepairs.com
4/29/2014 7:11:14 PM • Bosch 24 in.... • Answered on Apr 29, 2014
For a couple of months all dishes come out looking
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
8/13/2011 1:12:32 AM • Bosch 24 in.... • Answered on Aug 13, 2011
Bosch dishwasher runs down to
Welcome to FixYa.
Based on your description I'd say the issue actually is with the control...unfortunately. This is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated. Copy & paste this link (or click on it if it will respond) to your toolbar (explorer bar ?) and you'll see my complete solution for this issue.
http://www.fixya.com/support/t8763034-good_afternoon
7/13/2011 3:31:12 AM • Bosch 24 in.... • Answered on Jul 13, 2011
Soap residue; suddenly. No change in soap.
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
5/1/2011 12:25:22 AM • Bosch 24 in.... • Answered on May 01, 2011
Hello- My bosch dishwasher model shx33a05uc
This happens to Bosch dishwashers because the dishwasher stops heating the water and the dishwasher keeps running trying to heat the water up. Go to the link below and it will explain how to fix the issue.
http://www.appliancerepairlesson.com/2011/01/15/bosch-dishwasher-error-2h-dishwasher-error-code-repair-help/
Good luck
3/6/2011 1:26:05 AM • Bosch 24 in.... • Answered on Mar 06, 2011
Bosch shx33a05uc/14 dishes are milky with white
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
3/3/2011 2:11:04 AM • Bosch 24 in.... • Answered on Mar 03, 2011
My Bosch dishwasher is leaving white marks on my
it could be your water. minerals in water
12/16/2010 5:43:35 AM • Bosch 24 in.... • Answered on Dec 16, 2010
Machine won't start until 2nd
You could have a loose door switch.
I am assuming by 2nd or 3rd try you mean you have to open and shut the door and then press the start button.
Refer this diagram of the front panel. The door switch and lever are shown in the detail on the top left corner of the diagram. It is part 3 in the parts list.
Please post a comment to confirm if this is the helpful or not.
9/12/2010 7:03:19 AM • Bosch 24 in.... • Answered on Sep 12, 2010
Dish washer will not fill
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
8/5/2010 4:58:59 AM • Bosch 24 in.... • Answered on Aug 05, 2010
Dishes not getting clean
Raise your water heater temperature to 140 degrees.
Use FINISH TABLETS
If wash arms don't spin freely when dry, there are repair kits available.
12/20/2009 6:10:44 PM • Bosch 24 in.... • Answered on Dec 20, 2009
Soap dispenser door does not open during wash
Here's a link to an article on why the soap dispenser won't open and tests to find the issue so you can resolve it...
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=cup-wont-open
10/18/2009 6:01:49 PM • Bosch 24 in.... • Answered on Oct 18, 2009
Not draining; about an inch of graywater in bottom. Dishes not clean. Unit is about 5 years old.
hi there. let me help you. check these things below and get back if we did not isolate the problem for you.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
5/28/2009 5:09:17 PM • Bosch 24 in.... • Answered on May 28, 2009
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support 1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish... This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ... 9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone. 1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your ..https://www.youtube.com/watch?v=Xr4DBwACUW4
4/15/2024 10:37:04 PM • Bosch... • Answered on Apr 15, 2024
Water dripping out of last hole in Bosch upper spray arm getting dishes below wet
the unit could be un-level
3/22/2024 4:43:03 PM • Bosch... • Answered on Mar 22, 2024
Bosch 24 in. SHX33A05 Stainless Steel Built-in Dishwasher Logo
34 questions posted
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
bosch dishwasher runs down
  • Dishwashers
