20 Most Recent Jensen NAV104 GPS Navigation Add-On for Compatible - In-Dash Monitors Questions & Answers
Somehow my sd naigation card on the jensen JNA 62Bt needs to be reloaded.Is it possible
Contact Jensen to inquire.
11/19/2020 12:11:32 AM • Jensen GPS • Answered on Nov 19, 2020
Is there an update for JENSEN VX 7020 navigation system
You need to contact Jensen product support website.
4/5/2018 11:56:40 PM • Jensen GPS • Answered on Apr 05, 2018
0answers
Navsure n420i igo
Be the first to answer 4/26/2014 3:59:06 AM • Jensen GPS • Posted on Apr 26, 2014Be the first to answer
2answers
I want to update my
You need to navigate to the Horizon Navigation Online Shop (see Resources for the appropriate download page). Click on the Jensen manufacturer link located on the left menu pane. Choose your particular Jensen GPS model from the menu selection.
Choose the coverage area you wish to update your GPS unit with and choose to download the map updating software or have the software sent to you through the mail in DVD form. Fill out the order form information including your payment method (Visa, MasterCard or American Express are the only payment methods accepted). When you receive the updated software by either download or mail, install the software on your computer.
Follow the instruction prompts provided by the Navmate utility program with regard to updating your particular Jensen GPS unit's map software.
Hope helps.
10/29/2011 2:48:13 AM • Jensen GPS • Answered on Oct 29, 2011
2answers
I have model # NVX227
Lets see if we can get your unit first working by a common problem and possibly with a common fix. Try this and let me know if worked. It needs to be rebooted. Turn off, by holding off button down. Then once it is completely off, then turn it on, BUT when you go to turn it on, keep on button depressed, all the way until it turns on and then some for about 15 seconds, now you just rebooted system.
In most cases the touch screen develops a short locking up the screen, the only way to fix the problem is replace the whole touch screen fixture to address the issue, however my experience has shown it is more cost effective to replace the GPS device than having it repaired.
Thanks Mike
9/12/2011 7:03:39 PM • Jensen GPS • Answered on Sep 12, 2011
I have a jensen 9214
The least expensive solution would be eBay.
4/13/2011 11:17:19 PM • Jensen GPS • Answered on Apr 13, 2011
Need the Bluetooth pair code
Hi Charles
The factory code is 0000. If a previous user has changed this, you are out of luck.
Mark
4/5/2011 6:29:25 AM • Jensen GPS • Answered on Apr 05, 2011
WHERE CAN I GET A
Hello there,Here is a link to the PDF file that you need http://audiovox2.info/docs/jensen/man/VM9424_DOC_IM.PDFi hope this was helpful don't forget to Rate
1/26/2011 5:01:53 AM • Jensen GPS • Answered on Jan 26, 2011
0answers
Jensen NAV104 GPS Navigation Add-On for Compatible - In-Dash Monitors Logo
1 questions posted
Top Jensen GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Jensen GPS Expert? Answer questions, earn points and help others
View Most Popular
Jensen GPS
  • Jensen GPS
Most Popular Question
nvx430bt owner 39 s manuals need
  • GPS
