20 Most Recent Bosch Classixx WFO 2866 Front Load Washer Questions & Answers
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Bosch Classixx... | Answered on Feb 09, 2019
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Bosch Classixx... | Answered on Oct 30, 2016
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Bosch Classixx... | Answered on Jul 15, 2014
The display / control units are sensitive to voltage surges and it was most likely damaged when the fuse blew.
Bosch Classixx... | Answered on Apr 28, 2014
If all the lights are flashing it is without a doubt a faulty main board. If only certain lights are flashing it is showing an error code. Tell me which lights are flashing and will point you in the right direction. Approximately will cost 100 to 140 for a board, which also has to be programmed
Bosch Classixx... | Answered on Oct 19, 2013
There is no reset as such, if the motor shorted when the motor brushes went there is a good chance that it blew the motor tracking or relay on the board. Sometime this is indicated by F20 or F21. Unfortunately this will be a new board. You could try to run a motor test as follows:
Hold in the start button while turning the dial one click to the left (30 easycare) wait until the display shows 888 or two indicators light up next to dial.
Release start and turn dial to 60 cotton (WITHOUT GOING THRO THE OFF).
Press start
This should start a motor test
slow turn one way, slow turn the other, pump on then up to full spin.
(some machines will show the rpm on the display).
If this does not work, you probably need to change the module aswell.
Best of luck
Bosch Classixx... | Answered on Mar 21, 2013
Bosch Classixx WFO 2866 Front Load Washer Logo
72 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
bosch classixx 6 1200 express error code
  • Washing Machines
