20 Most Recent Bosch WFMC2100UC Nexxt Essence Washer Questions & Answers
Foul drain smell from machine
Sometimes the cure is near as bad as the problem... My first inclination would be to order a new gasket but you will still have to be in & around mold. Inspect the GASKET and make sure it is pliable & completely intact. Spray NOTHING directly on the gasket. Pardon my California spelling... but there are some anti-fungal sprays (in building supplies)... after you have the goggles, dust mask & gloves... get some disposable RAGS and protect EVERYTHING near-by... It is every bit as FRIENDLY (not) as industrial strength carburetor cleaner (face skin tightens up (not good)). Have a trash container close by: Sparingly ... and repeatedly... spray it on a RAG and apply it around your gasket and mating surface... wipe it clean. Rinse the gasket with clean water (on another rag). Apply food grade silicone to a clean rag and wipe down the gasket and the mating surface. Do NOT spray silicone directly on the gasket. Dispose of those rags like they are radio-active (well... ok... maybe just seriously obnoxious). Sorry to hear of your water/washer issues... Hope this helps Carnac the Magnificent
4/4/2017 1:54:19 PM • Bosch WFMC2100UC... • Answered on Apr 04, 2017
Unlock the door
Wait 5 mins and try again
7/12/2015 1:32:37 PM • Bosch WFMC2100UC... • Answered on Jul 12, 2015
I have a BOSCH WFMC2100UC/01 washing machine and it is shacking really violently during the start of the rinse cycle. What part is wrong with it?
Simply enter your load as it may not be balanced . Especially if the load is small.
12/19/2014 1:01:14 PM • Bosch WFMC2100UC... • Answered on Dec 19, 2014
How to replace drain pump?
take out the plug you need to remove the front cover first remove kick plate.then take out soap dish.. remove the door seal.. take of door lock..take 3 screws now remove the cover the pump can now be removed
8/19/2014 8:07:30 PM • Bosch WFMC2100UC... • Answered on Aug 19, 2014
How do you activate Bosch Nexxt Essence Washer diagnostic mode
You can find a PDF copy here: Bosch Classixx 5 Manual
7/15/2014 8:38:44 AM • Bosch WFMC2100UC... • Answered on Jul 15, 2014
I have wfmc2100uc the motor does not spin.I tested it and its in the ohms range. I plug it back in and it has 145v going to it but it doesn't work is this the right voltage
No should be no more than 120 vac.might have something caught in drum causing in to be locked up try spinning the drum by hand with unit unplugged.if it spins and motor spins with it belt should be looked at if it is in good shape and tight check you settings switch draw picture of wire locations for a reference later.unplug all wires with unit still unplugged of course ohm out settings if it is good than motor is in need of replacement.
5/18/2014 8:40:16 PM • Bosch WFMC2100UC... • Answered on May 18, 2014
0answers
Washing Machines Logo
87 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
washer quitting after wash cycle not
  • Washing Machines
