20 Most Recent Bosch Nexxt WTMC 6300 Electric Dryer Questions & Answers
MY BOSCH NEXXT 500 ELECTRIC DRYER IS RUNNING ON 20
Did you check this FIXYA LINK below? Appears to have lot's of answers! Also I WATCHED the YOUTUBE video I recommended and NOTICED his DRIVE BELT is WAY too loose! Methinks THAT is why his dryer has problems! Be SURE your belt is not to aged because they can STRETCH and then TRIP the "RESET SWITCH" he's talking about. Note the way his PULLEY shakes so violently... AND the action of the belt itself... 20 Most Recent Bosch Nexxt 500 Dryer Questions Answers Here is another Link! Bosch Dryer Won Heat 3 min FIX And yet another! Bosch Dryer Won Heat 3 min FIX (DON'T waste your time with the FOUR oval Links to the right! )
12/24/2017 4:13:47 AM • Bosch Nexxt WTMC... • Answered on Dec 24, 2017
Hello, my hi-limit fuse in a WTMC 6300 dryer
make sure the vent hose is clean and not kinked.clean the lint screen EVERY load! also check the seal around the door.
12/4/2017 5:47:22 PM • Bosch Nexxt WTMC... • Answered on Dec 04, 2017
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
6/6/2012 2:24:51 AM • Bosch Nexxt WTMC... • Answered on Jun 06, 2012
Lint is building up in
you will need to clean out or replace the vent line as you clothes will not dry if there is a restriction in the line.
10/4/2010 10:58:48 PM • Bosch Nexxt WTMC... • Answered on Oct 04, 2010
Dyer will not rotate just clicks
Welcome to FixYa.
I know I responded to your other post as well, but I just wanted to make sure you got my reply.
It sounds like the kill/emergency shut switch is in the "off" position.
  • If you notice a switch ( white in color ) next to the belt pulley has a black push button on it, that is the interrupt switch that shuts it down should the belt break.
  • Push in the black button from the left ( from the back ) until you hear it "click" and you should be good to go.
Let me know how you make out.
Thanks for choosing FixYa. I hope you will take a second to rate my solution/assistance positively.
Good luck.
Macmarkus :)
8/28/2010 1:25:08 AM • Bosch Nexxt WTMC... • Answered on Aug 28, 2010
Took the back off to get a screw out and when I
Hi, Welcome to FixYa. It sounds like the kill/emergency shut switch is in the "off" position. If you notice a switch ( white in color ) next to the belt pulley has a black push button on it, that is the interupt switch that shuts it down should the belt break. Push in the black buttonfrom the left ( from the back ) until you hear it "click" and you should be good to go. Let me know how you make out. Thanks for choosing FixYa. I hope you will take a second to rate my solution/assistance positively. Good luck. Macmarkus :)
8/27/2010 5:02:40 AM • Bosch Nexxt WTMC... • Answered on Aug 27, 2010
NOT HEATING
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
6/4/2010 1:51:20 AM • Bosch Nexxt WTMC... • Answered on Jun 04, 2010
Squeaking when running , belt?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
4/8/2010 10:39:39 PM • Bosch Nexxt WTMC... • Answered on Apr 08, 2010
Dry runs but the gas does turn on
bad ignition ignitor for the burner
2/25/2010 3:34:24 AM • Bosch Nexxt WTMC... • Answered on Feb 25, 2010
It is not throwing heat, only cold air
there is a resetable hi litmit fuse located on the side of the heating element can.this can be accessed by taking all the screws of the back panel then look for a small red button on the heating element can push the button in and this should reset the fuse. i hope this helps, let me know
1/22/2010 3:09:06 AM • Bosch Nexxt WTMC... • Answered on Jan 22, 2010
Dryer runs but doesnt heat. Used to just unplug
Sounds like you have to replace your thermostats in the back of the dryer. Also check to make sure your heating element is good
9/25/2009 8:52:19 PM • Bosch Nexxt WTMC... • Answered on Sep 25, 2009
Dryer was not staying on for more than a few
Maybe the vent chamber is plugged (considering you have kept the filter clean) Pull the filter out, and look down in the unit for excess lint. You may have to move the dryer to clean it all out.
6/5/2009 5:26:29 AM • Bosch Nexxt WTMC... • Answered on Jun 05, 2009
2answers
E-01 error code
hi there,
i understand your frustration here.
the E01 code means there is reduced airflow through your dryer and therefore before it overheats and starts a fire, it shuts down.
replacing boards and sensors will not fix this problem as it has nothing to do with the electronics or electrical side.
here is what you can do yourself:
check the venting on the dryer.
the vent hose runs from the back or side to the wall of your house.
it may be clogged or kinked
if everything is fine, i would contact Bosch directly and see if they have a recall or any service reports on this problem and if there are any solutions.
let me know if i can be of more assistance.
thanks.
2/4/2009 3:34:31 PM • Bosch Nexxt WTMC... • Answered on Feb 04, 2009
Will Not Start
hi there,
sounds like the touchpad is intermittent.
please provide the complete model # and i will look up more details.
thanks,
9/25/2008 2:35:57 AM • Bosch Nexxt WTMC... • Answered on Sep 25, 2008
Lint Filter
hi there,
i can understand your frustration. i have reviewed the information that i have from Bosch and they indicate that the lint filter indicator light should only come on as a reminder but should not shut off the dryer.
here is my recommendation and also a question:
the dryer is shutting off due to the fact that it's overheating. it's a safety precaution from the manufacturer and it's built in to prevent the lint collected in the lint filter, since it's highly flammable.
check the venting in the back or side, wherever it was installed.
the vent tube is often the cause for the dyer to stop functioning.
if that turns out to be okay, the dyer is equiped with a sensor on the heater. it is possible that it's opening due to the heat generated by the dryer that has nowhere to go.
does the display show any error messages?
can you tell me what they are?
thanks again
9/25/2008 2:22:28 AM • Bosch Nexxt WTMC... • Answered on Sep 25, 2008
Brand new Dryer with loud noise and hot
contact bosch for factory service on the unit
5/11/2008 5:34:45 PM • Bosch Nexxt WTMC... • Answered on May 11, 2008
No power
post your email here and i will send you the service manual on this model i need to know if you are in Canada or USA there is two diffrent models under the 6300
1/24/2008 7:32:01 PM • Bosch Nexxt WTMC... • Answered on Jan 24, 2008
Attn : Bosch Experts
i have one infront of me but not on my computer. what kind of problem are you having?
11/27/2007 3:13:34 AM • Bosch Nexxt WTMC... • Answered on Nov 27, 2007
Bosch Nexxt WTMC 6300 Electric Dryer Logo
Popular Tags
32 questions posted
Top Bosch Dryers Experts
vince
NOEL
NOEL
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dryers
  • Bosch Dryers
Most Popular Question
not throwing heat only cold air
  • Dryers
