20 Most Recent Moen YB2818 Eva Towel Bar Bathroom Accessory - Brushed Nickel Questions & Answers
Same problem. The key to releasing it is finding the 'latch' of the 'spring'. I wish I could upload a photo. It just snaps off the way the battery compartment opens on your TV remote. On a TV remote if you apply too much pressure then you break the 'latch' on the battery's door, as we all know it is about applying pressure it the right place of the 'spring'. Once I got the correct placement of the flat head screw driver it was easy, but it took me 30 minutes to figure that out and I broke a piece of the towel rack.
Moen YB2818 Eva... | Answered on Jun 29, 2019
u have to really push hard up on the spring and at the same time pull towards u
Moen YB2818 Eva... | Answered on Aug 24, 2015
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
Moen YB2818 Eva... | Answered on Jun 08, 2014
check underneath for a small setscrew. back this out and it should be removable
Moen YB2818 Eva... | Answered on Jul 08, 2011
Change shower. if u want repair open the controller and replace rubber washel.
Moen Home | Answered on May 14, 2019
Moen posi-temp cartridge. 1222/1222B
-or-
Moen 96988 Cartridge Repair Kit Posi-Temp 1 Handle tub/shower
https://www.moen.com/shared/docs/exploded-parts-views/82000pt.pdf
Best to have the Moen Cartridge Puller.
Moen Home | Answered on May 01, 2019
DUH HOW DOES ANY CARTRIDGE WORK ?
Moen Home | Answered on Jan 29, 2019
http://www.moen.com/shared/docs/instruction-sheets/ins10040.pdf
Moen Home | Answered on Jan 04, 2019
remove the head remove restrictor add a gasket reconnect
Moen Home | Answered on Nov 22, 2018
Just buy a backflow preventer and install it in-between the pipe coming out of the wall and the shower head. Most (all?) shower heads have 1/2? standard pipe thread. Home Depot sells a backflow preventer with 1/2? standard pipe thread for $6.97.
Good luck and hope this helps.
Moen Home | Answered on Nov 14, 2018
Moen YB2818 Eva Towel Bar Bathroom Accessory - Brushed Nickel Logo
14 questions posted
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
View Most Popular
Moen Home
  • Moen Home
Most Popular Question
tighten up loose moen eva towel bar wall
  • Home
