20 Most Recent
NOOK HD 7 Tablet Questions & Answers
It's says do not have permission to open browser any one help thanks
Have you checked the restriction settings on your Nook? Try checking to make sure the restriction settings have not been accidently turned on for the browser.
- Press the ? button to display the quick nav.
- Tap Settings.
- Tap the Security option.
- Tap Restrictions.
- Tap the Restrictions check box.
- Enter your four-digit code for Restrictions.
- Tap the Browser check box so that it's not checked.
Hope that helps!
Nook won't go past turn on screen
You need to do what is called a HARD RESET.
This resets your Nook back to factory (Just Out of the Box) defaults.
It will erase your internal storage but will not touch any external sdcard.
Turn the NOOK off completely.
Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds).
Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm.
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.General charging recommendations. If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off. Well that\'s about in in keeping the battery life and charge at its maximum. If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current. One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery. You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Nook cable doesn't fully insert into port for connecton?
It sounds liket he cable end or port either have something lodged in them or the cable end has been disfigured making it difficult to insert all the way. Us a magnying glass and check the cabl endfor disfigurement. Hope this is of help.
How can I install incredimail email program on my nook HD+ tablet?
I did a research Google on the terms 'incredimail Molto'.
Incredimail's support pages kept referring to Molto as an android app that can access Incredimail accounts via something called POP3. See Incredimail support pages and the Molto app in the Google Play Store app for details on usage.
Nook hd + will not charge at all
Seems you have a bad charging cable. You might purchase a replacement new one from B&N directly but that costs a arm and a leg. Do some research on Amazon and Yahoo shopping. Compare prices and you might just be able to score two or more for the cost B&N wanted for just one. As these things tend to get worn out over time it never hurts to have a spare or two. This happened on my old Nook Color. After digging around a while on Amazon managed to get two for just under $10 and free shipping. The shipping should be free as you can easily put two in standard large envelope.
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
