20 Most Recent Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR Questions & Answers
I have the same issue how do you replace it without removing the entire frame
Sterling... | Answered on Dec 02, 2018
where the cold water goes into the hot water heater (marked cold) there should be a "shut off" valve, close it then open it,...sounds like there is something stuck inside "before" all taps,.meaning your taps are fine,...things can get stuck in that one shut-off,....if this does nothing to rectify problem write me back with type of hot water heater,...boiler (tankless) or a tank,...electric or indirect from boiler
Sterling... | Answered on Sep 02, 2015
Ace Hardware sells that door and you will need to see if they can order the parts but it looka like they sell the doors 36" size so when you order you will need to order for the Sterling Plumbing 1500D-36S "Vista Pivot" Shower Door Fits Openings 31 -1/4" To 36" H 66" . Now if you have not completely finished the shower you could always make the door opening fit what you have.
Sterling... | Answered on Nov 18, 2014
Supplier in the Netherlands, www.novellini.nl
For the 30095PPC are the next parts:
De benodigde artikelnummers zijn:
1 x R02YOB2G-40 (set scharnieren t.b.v. één deur) à € 23,80 incl. btw.
De prijs van de bovenstaande set onderdelen is € 23,80 incl. btw.
Verzendkosten zijn € 7,50 incl. btw.
Sterling... | Answered on Apr 08, 2014
Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR Logo
40 questions posted
Top Sterling Plumbing Home Experts
Donni Steen
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
View Most Popular
  • Sterling Plumbing Home
Most Popular Question
need plastic pivot part door
  • Home
