20 Most Recent
Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White Questions & Answers
Where can I buy Caroma outlet seals?
Take the existing part to Lowes or Home Depot and look at there universaltoilet replacement parts. I bet you can find one that will fit.
7/29/2014 2:09:36 PM •
Caroma...
Answered
on Jul 29, 2014
I have a dual flush
There should be a float inside the tank of the toilet. Be sure that when the tank fills that the float is not getting stuck, or not floating all the way up and not sealing the flush valve at the bottom of the tank.
4/5/2011 1:45:11 AM •
Caroma...
Answered
on Apr 05, 2011
Flush mechanism is stuck; unable to push buttons
If it's electrical powered, you may have to spray alcohol in the buttons to free them, if urin or other contaminants have gotten behind them to make them stick to were there stuck.
12/27/2010 6:51:16 AM •
Caroma...
Answered
on Dec 27, 2010
Toilet will not Shut off!
the rubber flapper on the bottom of the tank is not seating on the drain and it is allowing water to leak out to the sewer, also check to see if water is too high in the tank and flowing out of the center overflow tube, if so adjust the height of the water level
8/19/2010 3:28:28 AM •
Caroma...
Answered
on Aug 19, 2010
Water fills tank slowly
Check your angle stop ==valve underneath close to the wall see if it's open all the way if it is and you still have the same problem then go ahead and shut it off, disconnect it from the toilet and the valve and see if there is anything stuck in the hose (a gasket maybe) if nothing blocks the hose then. Reconnect the hose starting from the valve put a bucket on the other side to catch the water and open the valve as if to clean the hose.
After you do that reconnect the hose and try again if still does not work properly then you have to replace the fill valve (the tower looking stuff inside the tank)
if it works for you, don't forget to rate me
thx
5/27/2010 7:09:53 AM •
Caroma...
Answered
on May 27, 2010
Cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
5/26/2010 2:52:03 AM •
Caroma...
Answered
on May 26, 2010
