20 Most Recent
Bosch KFU 5755 Refrigerator Questions & Answers
Bosch B26FT50SNS fridge. How to repair broken wire in left ice/water door?
To repair a broken wire in the left ice/water door of the Bosch B26FT50SNS fridge, it is possible to disassemble the left door water/ice dispenser. However, it is important to note that this process can be complicated and should only be attempted by someone with experience in appliance repair.
To begin, unplug the fridge from the power source and remove any items from the door shelves. Locate the screws that hold the dispenser cover in place and remove them using a screwdriver. Carefully pry off the cover and set it aside.
Next, locate the wire that needs to be repaired and determine where it is broken. Cut away any damaged sections of wire and strip the ends of the remaining wires. Twist together the ends of the wire that was cut and use electrical tape or wire nuts to secure them together.
Reassemble the dispenser cover by aligning it with the door and pressing it into place. Replace the screws that hold it in place and tighten them securely.
Finally, plug the fridge back in and test the ice/water dispenser to ensure that it is working properly.
In summary, to repair a broken wire in the left ice/water door of a Bosch B26FT50SNS fridge, you can disassemble the left door water/ice dispenser, locate and repair the broken wire, and reassemble the dispenser cover.
6/21/2023 8:42:28 PM •
Bosch...
Answered
on Jun 21, 2023
KGV28V01GB/21 light at half bright when door shut?
- Check the door switch: The door switch is responsible for turning the light on and off when you open and close the door. Disconnecting the switch, as you have already done, can confirm if the switch is working correctly or not. If it still remains at half brightness, the switch may need to be replaced.
- Check the light circuit: If the switch appears to be working correctly, there may be a problem with the light circuit. This could be a problem with the wiring or the bulb itself. You can try replacing the bulb to see if that resolves the issue.
- Contact Bosch Support: If the problem persists,
2/14/2023 1:13:53 PM •
Bosch...
Answered
on Feb 14, 2023
