20 Most Recent
Bosch HMT8625GB Microwave Oven Questions & Answers
Bosch Microwave Oven
The problem is most likely a bad magnetron, "heart of the system" or the inverter board has failed, "if less than 7 years old"
Hi, I'm after an antenna
I will advice you check either ebay.com or amazon.com to get the antenna for your device.
Take care.
Bosch Microwave HMT8625 range - Microwave not working
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new
microwave oven.
Door stuck.
It might be in a bind , lift up on the door (small flat driver)
but it is likely the lubrication is sticky.
a hair dryer pointed at the latch area may loosen it if so.
stay away from the display area.
and try pushing in or pulling out just a bit on door when pressing button. be gentle.
Thats about the best you can do without opening case.
Sick Microware
first unscrew the unit replace fuse "near transformer this fuse is for the heating" --i think ur microwave needs a proper ventilation..
