20 Most Recent Bosch HMT9656GB Microwave Oven Questions & Answers
0answers
Bosch HMT9656GB Plate not turning
THE TURNTABLE MOTOR HAS FAILED its easy to fix and doesnt involve going near high voltages remove microwave and flip it onto its roof a metal panel at the bottom covers it up if its never been removed before you will need to cut out strips holding plate in place. this reveals motor held in with 2 screws replace motor a cheap, part reverse fitting it should now work dont forget to fit drive dog and turntable glass before testing.
3/3/2017 7:36:49 PM • Bosch HMT9656GB... • Answered on Mar 03, 2017
Why does it get to hot and shuts down before end of timer and no ding, food stays cold
Check if the cooling fan is operating. If it is, either the thermal switch is bad (unlikely) or the magnetron is defective and overheating.
7/19/2014 8:05:21 PM • Bosch HMT9656GB... • Answered on Jul 19, 2014
The turntable is not working but I have power
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.....
9/2/2013 5:16:12 PM • Bosch HMT9656GB... • Answered on Sep 02, 2013
2answers
Bosch hmt9656GB bloybf fuse
how do you change the bulb on a Bosch microwave HMT9656
6/9/2013 7:44:12 PM • Bosch HMT9656GB... • Answered on Jun 09, 2013
Hi when i set the
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes and try again.
11/23/2011 6:03:25 PM • Bosch HMT9656GB... • Answered on Nov 23, 2011
Need manuel for Bosch Innowave microwave, type
I would call the store from which you purchased it to get Bosch's contact info, or do a Web search using the term Bosch and the country it was made for or the full model number.Be sure to look for the bosch domain name in the search results. If you just blindly select a FixYa link, you'll likely be thrown back into this convoluted, polluted hell of a Web site.
11/23/2011 6:02:32 PM • Bosch HMT9656GB... • Answered on Nov 23, 2011
My radiators are getting warm
You can check your microwave for possible LEAKS and make sure there are no FOOD particles blocking the oven's fan system To check for leaks, place a DAMP paper towel around the door seals and place a glass cup of water in the microwave. If there are leaks of microwave energy you will find DRY or WARM areas on the paper towel. BE CAREFUL not to peer or watch the test, done on level HIGH for 1 minute. Microwaves may cook the vitreous humor (liquid in eyeball,) just like it would an egg. If the towel is dry or hot ANYWHERE after the test, TOSS the microwave. Your safety is not calculated by the cost of a new oven.Let me know how this goes; I have tested many older ovens and have found quite a few leaky ones.
Sciencewoman
3/31/2011 5:41:33 PM • Bosch HMT9656GB... • Answered on Mar 31, 2011
Microwave oven type 9656 AU/02, works OK, but
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
10/26/2010 3:07:14 AM • Bosch HMT9656GB... • Answered on Oct 26, 2010
Bosch HMT9656GB Microwave Oven Logo
35 questions posted
Top Bosch Microwave Ovens Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Microwave Ovens
Most Popular Question
bosch hmt9656gb plate not turning
  • Microwave Ovens
