20 Most Recent
American Standard - Lavatory Faucet - Single Hole - Seva - 1480.105.002 Questions & Answers
I have an American Standard bathroom faucet. The
Assuming the drain plug is the pop-up type where you pull a small rod up behind the faucet, you can try the following:
In the cabinet below the sink you will see the rod come down that operates the sink drain plug. There is a horizontal rod connected to this that goes into the drain line with a small round cap. Unscrew this cap and pull the rod out. The drain plug should come up freely from the drain.
After cleaning reinsert the drain plug and be sure the horizontal rod goes into the drain and through the hole at the bottom of the drain plug shaft. Seat the round ball from the horizontal shaft into the drain line and tighten the round cap to hold the horizontal rod in the drain.
9/10/2014 10:27:58 PM •
American...
Answered
on Sep 10, 2014
I have an american standard bathroom faucet.
First, turn off the water supply under the sink. Next, put the faucet lever in the up position, no water should be coming out. While in the up position turn slowly while looking at the underside of the handle and you should be able to find a set screw. It will probable be an "allen head" type and you will need and allen head wrench to loosen it. An allen head looks like a hex shape, 6 sided I believe and is rod shaped. If you don't have one they come in sets at your local hardeware.
7/20/2010 3:06:05 PM •
American...
Answered
on Jul 20, 2010
How to fix a dripping faucet?
Hello. These faucets use a replaceable cartridge valve and when they drip they're ready for replacement. Remove the handle by loosening a small screw ,usually with an allen wrench, and maybe another nut under it.The cartridge should pull out but mat be stubborn. Take the valve with you when you go shopping there are many variations.
builderdale
1/23/2010 1:50:42 AM •
American...
Answered
on Jan 23, 2010
Removal of single hole kithcen faucet.
There is a bracket that slides between the threaded shaft and the bottom of the sink. There is usually a nut which is tightened up against this bracket. When this nut is loosened, the bracket will slide out. Of course, you first have to unfasten the two water supply lines. Once the bracket is removed, the two water lines which are made into the faucet are gently bent and the whole thing is removed from the top of the sink. Hope this helps.
3/9/2009 8:47:40 PM •
American...
Answered
on Mar 09, 2009
Clogged sinks and toilets
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
4/6/2022 3:13:10 PM •
American...
Answered
on Apr 06, 2022
Speed connect drain will not go down completely
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
12/10/2018 11:24:22 PM •
American...
Answered
on Dec 10, 2018
American standard 2k-2h still leaks after replaceing sem and nut
Did you replace or reface the seat (the surface in the bottom of the faucet body where the stem's washer "seats" itself to shut off the flow of water? There are special tools for removing the old seats and installing new ones (available from professional plumbing suppliers), or you may be able to renew the seat's surface with a special tool called a seat surfacer.
4/13/2018 10:58:01 PM •
American...
Answered
on Apr 13, 2018
How do i remove bathroom sink drain plug?
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
1/12/2018 10:02:19 PM •
American...
Answered
on Jan 12, 2018
How to replace the trap for kitchen sink..there is
open to drain pipes. remove the collars that hold trap on, sometimes you may need pliers or a pipe wrench to remove.install is reverse of removal the trap is there to contain the gases in drain pipe. if no trap. you will smell sewer water all the time. 1-1/4 for bathroom drains and 1-1/2 for kitchen sink drain.
9/13/2017 12:13:07 AM •
American...
Answered
on Sep 13, 2017
