20 Most Recent
RTO Waste King AH-780-UL Quick&Hot Instant Hot Water Dispenser - Tank Only Questions & Answers
Quick & Hot model AH-780
That center connection uses a clamp. You made no mention of the clamp in the post. Did you get a clamp with that unit? IT is a squeeze clamp and you put it over the inlet tube and connect the tube to the unit and then slide the clamp down to the connection and open the clamp and continue sliding it down over the nipple on the tank and then release it.
Waste king 1001 disposer is jammed and won't
Should be a place on the bottom of the unit to insert a hex or allen key to turn it to break it free... if its jammed. Make sure power is off/ disconnected prior to performing this task.
