20 Most Recent
Braun K 650 CombiMax Food Processor Questions & Answers
Sleeve on Braun 4621 Food Processor is loose. Rotates on metal post. Does not spin when contents are added to bowl.
It sounds like the cement that holds the two sections of the sleeve together has failed, causing the sleeve to become loose and rotate on the metal post. Unfortunately, this is not a repair that can be easily done at home, and it may not be cost-effective to have it repaired professionally, as parts for this model may be difficult to find.
One possible solution is to try to replace the sleeve with a new one, if it is still available. You may be able to find a replacement sleeve online or through a Braun authorized repair center. Alternatively, you could try contacting Braun customer service to see if they have any suggestions or solutions for this issue.
If a replacement sleeve is not available, or if the cost of repair is too high, you may need to consider purchasing a new food processor. However, it's worth noting that Braun food processors are known for their durability and longevity, so it's possible that a new one will last you for many years to come.
I need a new lid for Braun multipractic 4259. Who
Did you find a lid? I have a used one and would gladly send it to you for the cost of shipping from NH.
I warped the bowl for mine in the dishwasher and have since replaced it with a new food processor so would be happy to give away the useful parts (lid, pusher, blade, discs & carrier).
Printed circuit board
You may choose one of printed circuit board on RayMing off page
https://www.raypcb.com/ provide you with all you need to produce high quality printed circuit boards - just specify your board order as you need it, and we'll tell you how to optimize your order for your design priorities
