20 Most Recent
Hitachi C10FL 10" Stationary Table Saw 3.0HP Questions & Answers
My saw will not tilt fully, it keeps jumping the
Make sure the inner ring on the locking lever has not loosened up allowing it to apply some gravity pressure and is trying to catch. this happened to me...i could not get the blade to tilt very far and it started "clunking" inside the saw when i got just "so far". It sounded like it was "jumping a cog". I checked everything, a allen wrench" would tighten. Even outside heads on the cabinet . Sprayed everything with silicone. At the end of trying everything, checked the "lever" behind the wheel where you adjust the saw blade up/down (left turning wheel) and accidently discovered the lever had become loose and was tightening just from weight of the lever alone. I loosened the tension fully and the tilt works correctly now. No jumping. Dumb Luck discovery.RGS in Kentucky
