20 Most Recent Craftsman Push Block, Jointer Hold Down Questions & Answers
I need an owners manual for a Craftsman Router
sears.com go to toolsthem go to manuels and then downloads. then add your model number or the root model number for jointers like yours and you can get the free downloal, as long as the machine isn't older that the age of computers 1975 or about.
6/12/2010 5:23:27 PM • Craftsman Push... • Answered on Jun 12, 2010
2answers
Where can I find a manual for a craftsman nail gun model 58368429
Craft store
11/21/2022 7:53:51 PM • Craftsman Tools... • Answered on Nov 21, 2022
We are looking for staples for a Sears Craftsman Heavy duty staple gun (manual not electric)
If you google Heavy Duty Wide Crown 3/8 in Wire Staples there are hundred of sites that sell the staple amazon, Home depot, Lowes, Walmart
11/2/2021 6:49:11 PM • Craftsman Tools... • Answered on Nov 02, 2021
I need a diagram of the craftsman stapler 968514
1/29/2019 3:24:49 PM • Craftsman Tools... • Answered on Jan 29, 2019
I purchased a 320.27683 router and table. I am using craftsman 1/4 in bits. The 1/4 in collet nut will not tighten the bit . The bit just pulls right out. I left 1/8 space between the bottom of bit.
Take the collet fully apart and clean out all sawdust and other debris. Does this happen on all i/4 shank bits? use only quality bits preferably American bits. I use Whiteside and Amana, Cmt is a good bit. If it does not hold any 1/4 bit replace collet. To my knowledge Sears has never made a router, they just sell them. It's possible it was a Skill, a Black and Decker, or some other common brand with a few specs that Sears had them made with (good luck with that). Check router forum.com other people have looked for collets, there is many suggestion or answers. t site has them, but it does not specify 1/4 or 1/2 OEM Craftsman Router Collet Asy 2823121000 Ships Today Fix com
11/10/2018 7:24:17 PM • Craftsman Tools... • Answered on Nov 10, 2018
How do I change the belt on a Craftsman 3"x21" belt sander, model 31522580? This one is pretty old but still works. I couldn't find a manual anywhere for it.
First, I'm not a Sears Tech (ahh, not Lowe's either.) * Sears Parts; https://www.searspartsdirect.com/model-number/31522580/0247/0743000.html?searchType=modelSearch&q=31522580&searchTerm=31522580 * You can also look at the old belt and get the numbers off them. Check on Amazon.com for replacements. Aloha, ukeboy57
7/10/2018 10:43:56 PM • Craftsman Tools... • Answered on Jul 10, 2018
I need a manual for a Craftsman sander/grinder model 351.22638
I found the manual at ManualsLib here: https://www.manualslib.com/manual/487406/Craftsman-351-22632.html . I hope this helps. Cindy Wells
6/22/2018 10:42:13 PM • Craftsman Tools... • Answered on Jun 22, 2018
Taking apart craftsman bench belt/disc sander
If you want to best Disc/Best sanders go to the link https://bestdiscsanders.kinja.com/more-detail-about-belt-sanders-1823124699
3/29/2018 7:27:21 AM • Craftsman Tools... • Answered on Mar 29, 2018
0answers
I have an OLD craftsman 1 hp router that I haven't
It is supposed to be self extracting, meaning that if you turn the nut far enough, the bit will pop up; no need to remove the nut. If the bit is stuck, try to pull it out with pliers. You may even need penetrating oil. Probably just rust; there is not much that go wrong. Good luck. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
1/3/2018 10:19:43 PM • Craftsman Tools... • Answered on Jan 03, 2018
Adjusting tension on sanding belt Craftsman Mod 113-225831. Can't tell exactly where to adjust the tension to keep sanding belt from traveling inward.
it is not tension you adjust but parallel running of the front pulley normally there is a knob along the arm that you can move in or out carefully and you will see the belt run back to covering the pulley best do it when you spin the belt by hand as the adjustment is touchy
1/1/2018 3:14:16 AM • Craftsman Tools... • Answered on Jan 01, 2018
Have a Craftsman 12-inch wood lathe--want to know how much to sell it for???
Should buy old Craftsman lathe You also might see what others would be selling it for in either eBay or a trading post type of local community papers.
9/8/2017 9:02:52 PM • Craftsman Tools... • Answered on Sep 08, 2017
Craftsman Push Block, Jointer Hold Down Logo
1 questions posted
Top Craftsman Tools & Hardware - Others Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Tools & Hardware - Others
Most Popular Question
need owners manual craftsman router
  • Tools & Hardware - Others
