20 Most Recent Braun M880 MultiMix Hand Mixer Questions & Answers
My Braun Multimix 280 will only operate on
Yes. You can do two things. Replace the swith curcuit board or replace the triac/tyristor on the board itself. The last solution requires you to unsolder the triac and loosen it from the heatsink(110v veriosn only. 230v version has no heatsink) and test it with a multimeter to establish if it has failed. (Testing of tracs can be googled.) In eather case you will need to open the casing.
1. remove the base palte by lifting the end opposite to the electric cord.
2. Loosen the bottom power outled slider, without removing it fully
3. unclip the curved plastic retainer in the front and unscrew philips head screw.
4. Work around the edges of the two halves until it comes apart and you are able to free the slider from its return spring.
Replace the cicuit board completely if available. Or resolder a new triac observing the orietation of the pins and reattach to the heatsink by riveting/cliping on or whatever applies to you model. Using heat conductive silicon paste between triac and heatsink is a good idea if it is originally fitted (if white paste residues can be seen). The European 230 v version do not have a heat sink, due to the higher voltage and thus lower current opassing through. If the Euro version, simply replace the triac, trim the pins on the back of the board nad put back in place.
Triacs can be obtained from any electronic componets dealer, as long as you can supply the code stamped on it. The Euro version has code TIC226N, which you can find in any component or manufacturer cross refereanse table. TIC226N basically means a 8 amp triac. Triac is simplified just a sort of ac transistor. The US version I do not have the code for, but it must have a higher ampere rating, thus the heatsink
To replace;
Put all internal componets back in place in the right halve. Put the left halve on top and fit properly by gently pressing together. Fit the screw in the front and the retaining clip. Fit the sliding cover by cliping it back on, observing that the notch for the return spring will meet the spring pin on the right side for it to snap in place. The spring pin can be observed through the slots for the sliding cover. Then insert the base plate reversely of how you removed it.
The problems of these mixers, is that if overloaded the maximum current rating of the triac's may be exceeded. This will cause the triacs to short curcuit and therefore will give full power in any mode.
To avoid the problem, avoide heavy batters, heavy doughs and prolonged high load tasks. Otherwise a very handy smart little mixer that should last for years.
9/27/2016 9:18:57 AM • Braun M880... • Answered on Sep 27, 2016
What is wrong with my Braun Multimix 280w?
I'm afraid the gears inside are worn off. But perhaps it is worth to open the mixer, to see if perhaps only a screw came lose, so the slip comes from there. If you are not technical don't try this yourself.
6/11/2014 12:16:08 PM • Braun M880... • Answered on Jun 11, 2014
0answers
Switch
Be the first to answer 3/31/2014 3:10:50 AM • Braun M880... • Posted on Mar 31, 2014Be the first to answer
0answers
Open case
Be the first to answer 3/3/2014 4:31:26 AM • Braun M880... • Posted on Mar 03, 2014Be the first to answer
0answers
My mom
Be the first to answer 1/21/2014 7:45:07 AM • Braun M880... • Posted on Jan 21, 2014Be the first to answer
3answers
The switch is broken
Mine did the same thing. I found the ball bearing inside the switch had fallen off. Put it back on and it works like new!
Pull the mixer case apart. Push in on the seam in the front and back and it will pop open after you remove the 1 screw. Pull the switch apart. There is a spring inside the top part of the switch and a small (1/8") ball bearing should be on top of the spring. Chances are, it has fallen off. Find it and stick it back on the spring while holding the top part of the switch upside down. Put the mixer back together.
11/11/2013 7:16:26 PM • Braun M880... • Answered on Nov 11, 2013
0answers
0answers
0answers
Braun 4642 Mixers user guide
http://www.user-manual-pdf.com/appliance/handmixer/braun/instruction/braun-multimix-4642-handmixer.html
11/13/2012 2:17:54 PM • Braun M880... • Answered on Nov 13, 2012
Braun M880 MultiMix Hand Mixer Logo
67 questions posted
Top Braun Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
Tahir Hussain
Tahir Hussain
umar waheed
Are you a Braun Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Braun Food Mixers
  • Braun Food Mixers
Most Popular Question
braun multimix 280 will only operate
  • Food Mixers
